-   -   Insulating Engine Compartment (https://www.offshoreonly.com/forums/general-q/181209-insulating-engine-compartment.html)
NKissau 03-02-2008 04:46 PM
I have a 23' bowrunner with twin 4 cylinders that run at 10k RPM WOT. I know it's not an offshore boat, but this is my favorite site on the internet and I thought it would be ok to ask. Needless to say it is impossible to talk at all with passengers due to the noise. Has anyone installed the insulation blankets available from West Marine and other places? Did you notice a difference? Do they create a lot of extra heat in the engine compartment? Thanks in advance. Nick
dogturd21 03-02-2008 07:13 PM
10k at WOT ? hmmmm.......
Anyhow, look up a company called Sounddown on the web.
http://www.soundown.com/
NKissau 03-03-2008 05:56 AM
http://www.boatinglife.com/article_content.jsp?ID=9214
2nd Paragraph 5th line.
"You'll have more fun running both of these powerful, fuel-efficient monsters as they accelerate to 10,000 rpm and nearly 50 miles per hour."
Anyway thanks for the link!
hoozeyurdaddy 03-03-2008 08:28 AM
the blankets from west marine work pretty well, make sure you have good air flow though the engine compartment and run 91 or better fuel, if not the engine will heat soak when you stop and vapor lock. the higher octane fuel won't boil til a higher temp.
good luck.
NKissau 03-03-2008 10:20 AM
Thanks, I run on 87 and don't know if it's worth the extra fuel costs just to reduce the noise. I would have never thought about that.
dogturd21 03-03-2008 12:02 PM
Of just run the engine compartment vent fans longer after shutdown.
BY U BOY 03-03-2008 12:30 PM
or just open the hatch. I do that in the summer after a hard run.
1BIGJIM 03-03-2008 12:32 PM
I assume you mean the blower
DMOORE 03-03-2008 12:43 PM
A buddy has the same boat, and you're right. That thing is loud at cruise. I think some insulation would help it out a lot .When we are in our Ski Centurian, it's no problem holding a conversation cruising down the river. But for some reason the noise in the Yamaha reverberates into the cockpit. From outside the boat, it isn't loud at all.
Darrell.
NKissau 03-03-2008 01:01 PM
Running blowers or leaving hatch open is an easy option, but wasn't hoozeyurdaddy concerned about boiling the gas while under way?
DMOORE, you're right. On shore, you can't even hear me go by, but in the cockpit, it's like sitting next to two R1's wide open.
