575SCi Valve Springs? >
Old 03-05-2008 | 06:33 PM
Default 575SCi Valve Springs?
Freshing up the heads on my 575SCi's and adding Whipple innercoolers. What should I use?? Merc or aftermarket and what brand/part number?
ciaoderhead is offline
Old 03-05-2008 | 06:44 PM
Isky valve springs.
formula 382 sr-1 is offline
Old 03-05-2008 | 09:48 PM
H2Xmark's Avatar
are the stock springs a gold color or black??
H2Xmark is offline
Old 03-06-2008 | 07:33 AM
Black with yellow paint marks
Old 03-07-2008 | 02:07 PM
Ttt?
Old 03-07-2008 | 03:43 PM
H2Xmark's Avatar
I think the black springs from merc are the Comp cams springs, they had an earlier design then changed if i remember right, they should be good to run unless you are changing to bigger cams or turning more than 6000 rpms
H2Xmark is offline
Old 03-07-2008 | 04:36 PM
Thanks Mark
I talked to the Comp Tech line yesterday. The closest they have to stock spring spec. is P/N 924. It has a lower seat pressure and lower lift pressure. It's not a direct replacement and I will have to get new retainers and locks. The Whipple kit includes remapping the ECM and raises the rev limiter to 5600 from 5300 rpm. Seems assbackwards to raise rpm and lower spring pressure
Anyone with some first hand experience? Thinking stock Merc springs might be the easiest.
Thanks all
Old 03-08-2008 | 12:55 AM
MM1
Call isky and try the 8802 springs
MM1 is offline
Old 03-08-2008 | 09:35 AM
H2Xmark's Avatar
what is your seat pressure, i would think about 145 lbs, i know you dont want much over 150 seat pressure with a hyd. cam
H2Xmark is offline
Old 03-08-2008 | 10:12 AM
H2Xmark's Avatar
i am using the crane springs on my 500efis Part Number: 99895-16, they also have an updated spring av. as Part Number: 99896-16.
H2Xmark is offline
