Question on 502 compression ratio, octane >
Old 03-07-2008 | 03:35 PM
hey hows that magnum run? my buddy had a 27' t-sblocks, great boat.
scarabfun is offline
Old 03-07-2008 | 03:53 PM
I think you could easily run 89 octane with 9.1 CR and aluminum heads.
Also confuse don the specs. Valve sizes are wrong, as well as head chamber size says 218 cc.
The emi's should be fine, but you need to find out what the lobe sep is on the cam to make sure. It needs to be 110 or higher.
Griff is online now
Old 03-07-2008 | 04:34 PM
BY U BOY's Avatar
Lobe on the cam is 110 and you are right the heads should be 110, which is going to bring the ratio up to about 9.8:1
BY U BOY is offline
Old 03-07-2008 | 06:06 PM
Seef158, take a look at classified Ad Number: 20702
31scarab31 is offline
Old 03-07-2008 | 06:07 PM
BY U BOY, HOW CAN I FIND THE SCARAB LOGO THAT YOU HAVE? [email protected]
Old 03-07-2008 | 06:52 PM
Not too crazy about a used engine, don't want to buy someone's headache.
seef158 is offline
Old 03-07-2008 | 07:06 PM
No problem I understand, but absolutely no hedaches. I finally am getting my new 555ci's finished, 2 year process!
Good luck with what ever you decision may be. Summer is almost here! Have fun this year on the water!
Old 03-07-2008 | 11:41 PM
BY U BOY's Avatar
go to http://www.wellcraft.com/ click on online store scroll down to Scarab and click on it and you will see it.
BY U BOY is offline
Old 03-08-2008 | 10:03 AM
Thank you By U Boy!!
Old 03-08-2008 | 10:14 AM
BY U BOY's Avatar
No problem.
BY U BOY is offline
Hot Boat
13
10-30-2006 11:26 PM
Rage
4
09-07-2006 01:40 PM
P Offshore
5
04-24-2005 07:36 AM
seahawk
2
05-24-2004 12:21 PM
zokman
9
02-11-2002 09:10 AM
