Combustion Chamber Video >
Old 03-07-2008 | 05:45 PM
Strip Poker 388's Avatar
Rob
Thumbs up Combustion Chamber Video
Repost but its pretty cool vid
[YOUTUBE]http://www.youtube.com/watch?v=ec0tczrYuYc[/YOUTUBE]
Strip Poker 388 is offline
Old 03-07-2008 | 05:59 PM
Rob
2 stroke v 12
[YOUTUBE]http://www.youtube.com/watch?v=Rny-xutum0c[/YOUTUBE]
Old 03-09-2008 | 09:29 AM
H2Xmark's Avatar
first video is pretty cool !! that slow motion lets you almost see frame by frame
H2Xmark is offline
Old 03-09-2008 | 10:43 AM
that motor was lean. cool vid none the less.
Unitek is offline
Old 03-09-2008 | 11:07 AM
satisfactionII's Avatar
to me it looked like the spark was mutiple sparks. I always thought the the plug sparked one time for each time it fired. What is it really doing?
satisfactionII is offline
Old 03-09-2008 | 01:08 PM
Wink
Excellent footage of flame burn and propogation of the flame in the cylinder after ignition. If it was slowed down a bit more one could really tell if the flame burn and travel was good in the combution chamber. As you can see there is really no explosion in a cylinder when a motor is running correctly just a fuel burn and resulting pressure wave that drives the piston down. You can also see here the actual breathing of the cylinder with the air/fuel mix in and exhaust out and notice whn initail ignition tended to start with respect to TDC on the piston, looked a little late?
Regards,
Ray @ Raylar
Raylar is offline
Old 03-09-2008 | 10:57 PM
Rob
Regards,
Ray @ Raylar
Just think what a top fuel dragster would look like ,Im guessing a big red flash that looks like it last seconds
I would like to see the tip of the camera that took the vid$$$$Makes ya wonder the material that its made of that would handle thounds of a degree temps?
Old 03-09-2008 | 11:41 PM
It might be just the way the video was taken. However, the Capacitive Discharge ignition systems do use short multiple sparks.
Michael
Michael1 is offline
Old 03-10-2008 | 09:55 AM
Wink
Most of the newer coil near plug ignitions use the electronics in the coil and ECM to generate a phased spark array at the plug on lots of current engines to help with fuel/air ignition. Thats why some of these expensive aftermarket (red) coil systems are a great gimmick, you pay more for what you already have!
Regards,
Ray @ Raylar
Raylar is offline
Old 03-10-2008 | 12:40 PM
Rob
Regards,
Ray @ Raylar
I would bet GM does more R&D that the red coiled companys
