Compression Ratio >
Compression Ratio
Compression Ratio
Old 03-13-2008 | 12:44 PM
Default Compression Ratio
I was told by my machinist that the compression ratio on my engine should be right around 9:1. Since I did all of the final assembly on the engine I would like to find a way to test this ratio. Is there a way to check this information with a compression test or other method prior to running the engine?
Thanks in advance
Deltarat is offline
Old 03-13-2008 | 01:26 PM
BY U BOY's Avatar
Check the sheet that came with the pistons you have. It is also going to depend on the heads,cam and thickness of your head gaskets.
BY U BOY is offline
Old 03-13-2008 | 01:28 PM
Rookie's Avatar
You need these numbers
Rookie is offline
bcarpman
2
09-03-2006 08:59 PM
danielthelen
5
05-09-2005 02:44 PM
seahawk
2
05-24-2004 12:21 PM
daveo1
7
02-04-2004 09:17 PM
HARRISONMIRAGE
1
12-13-2003 07:17 PM
