Engine guru's/ fuel injectors >
Old 03-13-2008, 09:57 PM
Default Engine guru's/ fuel injectors
I am freshening and upgrading a bit. I have a 454 Mag 60 over, 7lb boost ProCharged M3 SC, Merc ignition, and the following additional. Edelbrock aluminum heads #61559 2.50 intake 1.90 exhaust, long runners are 320 short are 310, 118 CC, compression is 10:1. Cam is 236/238 @ 50 112 LC lift is 595 total custom grind with 1.8 rockers full hydraulic roller. I am currently running 50lb injectors. Will these work or should I go with 60lb injectors.
EMI Thunder exhaust. any thing besides the the reflash and possible injector change am I'm missing anything.
Bob
RBeyer is offline
Old 03-14-2008, 08:25 AM
50# should be okay. It all depends on how your ecm is mapped.
kennyo is offline
Old 03-14-2008, 12:00 PM
Charter Member #601
Mr Gadgets's Avatar
Do you have any idea what horse power was before making the improvments? And what about % of duty cylce on the old setup? What is the fuel PSI?
If you dont have a way of looking at duty cycle, then hp and psi #'s will help.
Mr Gadgets is offline
Old 03-14-2008, 03:01 PM
Bob
7 LBS on a 10-1 Motor seems on the high side .....Also 2.50 is a huge intake valve ...sure it is not 2.30?
Better get lots of fuel to it for sure.....
Bryan
Bryan Rose is offline
Old 03-14-2008, 05:57 PM
GPM
50 lb injectors, base fuel pressure set at 43.5, boost referenced regulator, 700 hp.
GPM is offline
Old 03-14-2008, 06:29 PM
That is surely a misprint... 2.5 intake valve on a 320 head? Highly doubt that.... the valves wouldn't clear the bore on a 454.
I think 10:1 with that much boost is gonna be really pushing it with 7 lbs on pump gas. Watch closely for detonation!!!
I think GPM has a pretty good baseline.
niceguy is offline
Old 03-14-2008, 07:11 PM
Estimations were in the low 700's prior, Don't have duty cycle. Fuel pressure at WOT is 78 to 80.
Bob
RBeyer is offline
Old 03-14-2008, 07:24 PM
These are the actual speck:
Edelbrock 61559 - Edelbrock BB-Chevy Performer RPM Aluminum Cylinder Heads
BB-Chevy Performer RPM 454-R Marine Aluminum Cylinder Head
315cc/300cc (Long/Short) Rectangle Ports
118cc Comb. Chambers
2.250''/1.890'' Valves
7/16'' Rocker Studs
Sold Individually
They have been ported significanlt to the 320 -310 runner. Every thing else is correct.
RBeyer is offline
Old 03-14-2008, 07:27 PM
GPM
Bob
why so high? what was the pressure at idle?
GPM is offline
Old 03-14-2008, 07:41 PM
36
RBeyer is offline
Quick Reply: Engine guru's/ fuel injectors
