difference between a 496 mag and 496 ho >
Old 02-16-2002 | 10:15 AM
NVRENOUGH
Default difference between a 496 mag and 496 ho
After comparing these two motors on the mercruiser web site I am left with a question. what exactly is the differce between these two motors. they have almost the exact same page except for the horsepower. so what is the difference, cam? it is the only spec that they don`t list.
thanks
jason
Old 02-16-2002 | 04:57 PM
Indy's Avatar
Member #154
This topic came up not too long ago. Do a search on 496 or 496HO. I think the 496HO has a forged crank, different cam, and chip is programmed differently.
Indy is offline
Old 02-17-2002 | 09:16 AM
Mike Shaak
I believe that the main differance is that the 375 has a cast iron crank, which I don't think is balanced. The cam is also differant,
WOT is 4400- 4800, the HO is 4600- 5000. The HO has better internals, from what info I can get. I hope this helps.
Old 02-18-2002 | 12:25 PM
CigDaze's Avatar
Arrow
Check out this link from GM:
http://www.gm.com/automotive/gmpower...rine/index.htm
496 MAG (375hp)
Block: Cast Iron
Cylinder Head: Cast Iron (with exhaust valve seat inserts)
Intake Manifold: One Piece coated Cast Aluminum
Crankshaft: High-Density Nodular Iron (with undercut and rolled fillets)
Pistons: Hypereutectic Cast Aluminum
Connecting Rods: Forged 1141 SAE Steel (short -peened and magnafluxed, with 9-mm diameter connecting rod bolts.
496 MAG HO (425hp)
Block: Cast Iron
Crankshaft: Forged Steel (with undercut and rolled fillets)
Both are internally balanced. Besides the above, there is a different cam and programming between the two.
CigDaze is offline
TeamPSI
23
12-10-2007 05:23 PM
never enuff
Baja
2
09-22-2007 09:36 AM
apexer
11
07-20-2007 07:24 PM
westcoaster
3
08-08-2005 11:24 AM
bn
4
01-15-2005 07:40 AM
