Can someone confirm trim pump diagnosis? >
Old 03-19-2008 | 09:26 PM
Default Can someone confirm trim pump diagnosis?
Symptoms: Trim pump will not run on 1 of the drives, solenoids click both up and down. I measured the voltage to the positive solenoid terminal and I am getting 12 volts. I jumped from the positive terminal to the blue/white motor wire and the motor did not work. This does mean the motor is bad doesn't it? I do not have trim limit wires. The only thing that is strange is that last year the trim down switch which is located on my Marine Machine throttles would not work, I had to use the dash switch to do this. Is this definitely two seperate problems or could it just be the one pump? Thanks for the help. Eric
SkiDoc is offline
Old 03-19-2008 | 10:35 PM
Sounds like two problems. When you crossed the red to the blue/white you were crossing both at big lugs on solenoid? If so pump is bad or has lost its ground. You can try some love taps on top of trim motor while clicking solenoids for a short term fix. Pump can be stuck and shorted or have an open circuit.
Also some have a square fuse block connector on the solenoid. You can jump around it to trouble shoot.
MOBILEMERCMAN is offline
Old 03-20-2008 | 05:46 AM
I get twelve volts when I connect the leads of the volt meter to the positive post and the ground(Also the ground for the other pump which works) I also get 12 volts before and after the fuse block. When I do this on the other pump it works!
SkiDoc is offline
Old 03-20-2008 | 06:16 AM
Registered User
Nothing worse than sliding off the trailer on the Friday before a holiday weekend and finding that your drive that's tilted up won't tilt down. It's just one of those things that happens. I have a spare as well as spares for the other ittems you can't get at a NAPA on a Sunday morning.
If one's bad, assume the other one is too. They've both been doing the same amount of work and getting the same amount of vibration and moisture. The "working" one probably isn't far behind.
Chris Sunkin is offline
Old 03-20-2008 | 08:24 PM
Boat Doctor's Avatar
Registered User
if you put 12 volts to the bule white or green white wire and the motor did not work it is the motor that is bad.
Boat Doctor is offline
Old 03-20-2008 | 08:52 PM
Thanks, I'll order a new one(or two thanks to Chris!) Eric
SkiDoc is offline
Old 03-20-2008 | 09:13 PM
Rookie's Avatar
take it to a local mom and pop starter/alternator rebuild shop and have the "old man" behind the counter thats been rebuilding stuff for 50 years look at it. He will clean out all the years of corrosion, put in $3 worth of brushes and send you on your way for $35. Thats what I did. If he can't fix it your out a $20 diagnosis. Those guys can do anything.
Rookie is offline
Old 03-23-2008 | 08:22 PM
kenvik01's Avatar
Registered User
Eric,
H&H Elec. her in Hendersonville does this. They've built many a heavy duty alt. for race apps. They've built 2 for me over the years. Dean could also prob. name a few, as he has several auto shops as clients. Ken
kenvik01 is offline
Old 03-24-2008 | 08:53 PM
Thanks for the heads up about the rebuild, I ordered a new one, I will have the old one rebuilt and keep as a spare. Thanks again, Eric
SkiDoc is offline
CNC
2
06-10-2006 07:36 AM
ratman
01-26-2006 07:48 PM
Poorsche
2
04-23-2005 06:48 PM
