upgrading gen 6 mechanical fuel pump >
Old 03-26-2008 | 08:41 PM
Ran-Dom 32's Avatar
Default upgrading gen 6 mechanical fuel pump
how much HP with the stock fuel/sea water pump support? has anyone tried the new KEPP fuel pump upgrade? I have a fresh pair of 540's that I don't want to starve for fuel
Ran-Dom 32 is offline
Old 03-27-2008 | 07:56 AM
Me too ........ same question, 'cept I have a single BB, close to the same CI.
Anyone ???
Kidnova is offline
Old 03-27-2008 | 08:19 AM
Nordicflame's Avatar
A Holley or Carter high volume pump diaphram assembly will screw right on to the Merc armature housing. Works great!
Dave
Nordicflame is offline
Old 03-27-2008 | 08:31 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
Merc. used the stock fuel/water pump on their SC-600hp. The KEPP fuel pump upgrade is good for 700hp. This Billit pump is rated for 850hp.
Attached Thumbnails upgrading gen 6 mechanical fuel pump-1_a_billet_pump.jpg
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 03-28-2008 | 10:20 AM
Dave
Dave, Have you tried/used a Holly or Carter diaphram on the Merc housing ? If so, which one did you use and how did it work out for you ? I have a 557 that should max out in the 5700-5800 RPM range. I'd like to stay with the mechanical pump if possible.
Thanks - Bill
Kidnova is offline
Old 03-28-2008 | 10:22 AM
Bill,
What's the PSI on the pump you mention ?
Kidnova is offline
Old 03-28-2008 | 10:44 AM
Thanks - Bill
Bill,
The Holley 12-454-11, 12-454-13 and 12-454-20 will all bolt up as will the Carters with the six screw flange (the Merc armature housing is a Carter unit)
Yes, I have used the -11 for a supply pump for the high pressure pump on supercharged EFI setups up to 1000hp. The -13 and -20 will require a regulator.
Dave
Old 03-28-2008 | 11:22 AM
Thanks Dave !!
Kidnova is offline
Old 03-28-2008 | 12:36 PM
Bill,
It's 8 psi and 1200 lbs. per hour.
[email protected]
302-521-0123
Old 03-28-2008 | 02:21 PM
Ran-Dom 32's Avatar
I think I'm going to try the KEPP pump, they are self regulated right? who's got the best price on a pair??
