1997 mpi vapor lock problem  (help) >
Old 07-28-2008 | 05:01 PM
Originally Posted by Inspector
Hi, I have two 1997 502 MPIs and have had vapor lock problems only after shutting the engines off for an hour or so (never while at idle). I posted the issue here last year and one of the suggestions was to add Marvel Mystery Oil to the fuel as it raises the boiling point of the fuel. This worked for me... As far as the adding an in line electric booster pump, that applied to engines which do not have the water pump mounted mechanical fuel pump (my 97s have the mechanical pumps).
Good luck...
this is interesting more details please.
rssteiny is offline
Old 07-28-2008 | 09:20 PM
does this apply to the 1996 model 502 mpi as well?
cloudmaster_321 is offline
Old 07-29-2008 | 06:22 AM
obnoxus's Avatar
Charter Member #1171
It is for motors without the mechanical pump on your sea pump,,,, ,, but I believe your gen does
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 07-29-2008 | 07:42 AM
correct, it does
Old 07-29-2008 | 07:47 AM
Ted G's Avatar
96 is the break year. You could have the VST system (small canister on top of engine) or the cool fuel system (no mechanical fuel pump).
www.cbpba.com
Ted G is offline
Old 07-29-2008 | 07:52 AM
satisfactionII's Avatar
can anyone supply or post the bulletin to fix this problem. It would be greatly appreciated
satisfactionII is offline
Old 07-29-2008 | 10:23 AM
Dave_N's Avatar
This one?
http://www.boatfix.com/merc/Bullet/99/99_07.pdf
Mercruiser service bulletins up to '02
http://www.boatfix.com/merc/Bullet/sbcover.pdf
Download Mercruiser Service Manuals - free
http://forums.iboats.com/showthread.php?t=251571
Dave_N is offline
Old 07-29-2008 | 12:02 PM
Pat McPherson's Avatar
Hey guys, if anyone wants a VST tank thingy from a 1994 I've got one you can have for the shipping cost.
I got it from a fellow I bought some EFI parts and he included it. I have the cool fuel so it no use to me.
Patrick
Pat McPherson is offline
Old 07-29-2008 | 01:42 PM
Originally Posted by rssteiny
this happened again this past weekend to my buddys boat, anyone ever fix the problem once and for all.
When I had the vst 502's in my boat I had the same problem, I fixed it by running a return line back to the fuel tank rather than recirculating it. That was the long term fix, short term if it vapor locks on you, crack the fuel line open to release the pressure, tighten it back up and the motors will start, as soon they start get up on plane and going to get fresh fuel through the system and your good until next time.
RonS is offline
Old 07-29-2008 | 02:37 PM
routing the return line to the tank is the correct way. also... simple thing is when you enter the no wake zone, just crack the engine hatch a couple inches... that will cool everything off very quickly and keep the heat soak to a minimum.
stevesxm is offline
