scarab hard alarm >
scarab hard alarm
scarab hard alarm
Old 04-16-2008 | 03:52 PM
Glad you found it. Don't put sealant on the new sender when you install it. It grounds itself throught the threads.
Griff is offline
Old 04-16-2008 | 05:42 PM
Ahhh, the power of OSO! Good work!
MacGyver is offline
Old 04-16-2008 | 06:41 PM
offthefront's Avatar
Originally Posted by SCARABJ
no on my 33 avs it would buzz until it built more than 5 psi of oil pressure then would go off..
did it ever have more than 5lbs????
offthefront is offline
Old 04-16-2008 | 08:41 PM
Default tan/brown?
On my eliminator I have a tan/brown AND the tan/blue that everyone else has. My buzzer was plugged into the tan/brown and did not work. Wonder if you have a tan/brown also, and why or why/not? I know its a shot in the dark, but maybe your buzzer is plugged into this wire?
Yellow_ICC_OK is offline
Old 04-16-2008 | 08:56 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Originally Posted by jimishooch
ok, here goes, found three sensors with the tan & blue stripe wire. one was on the drive bottle, 2nd on left side of the t-stat housing and the 3rd on top of the intake manifold close to the t-stat housing on the right side.
jim
Why are there 2 sensors at the T-stat housing with the tan/blue wire? Should only be 1.
US1 Fountain is offline
Old 04-17-2008 | 08:01 AM
yep, you're right, that's when i was a rookie. tan/blue on the right into the intake.
jimishooch is offline
Old 04-29-2008 | 07:31 PM
just to close this thread, it was indeed a bad oil pressure switch. installed new switch and am back to normal start-up alarm.
Nordic Matt
0
07-13-2008 10:37 PM
danno478
03-04-2007 10:40 AM
RutRow
2
09-12-2004 05:39 PM
waden54
0
06-08-2002 04:23 PM
waden54
12
06-06-2002 10:12 PM
