454 thread repair.... >
Old 04-13-2008 | 04:41 PM
Full Force's Avatar
Default 454 thread repair....
I have markIV 454's one block has had some helicoils done for the head bolt threads, no big deal... well one must have been tapped at an angle and the bolt will not go in with the head on, It was a running engine until I took it apart, I have no idea how they had a bolt in it before, I am using new hads and bolts, I cannot see if thye modded anything to make it work. The threads are not the greatest to hols the helicoil, is there a wat to tap it bigger then the 1/2" and also still use a 7/16" helicoil?
I want to retap the hole but the threads for the 1/2" tap are not good, what is the next size up? I cannot imagine I have to scrap a block for one thread...
Full Force is offline
Old 04-13-2008 | 05:39 PM
you may need to take it to a good machine shop....they should be able to care of this..Rob
ezstriper is offline
Old 04-13-2008 | 06:17 PM
there are inserts called ''timeserts'' that take a bigger hole they might work
dmaxx3500 is offline
Old 04-13-2008 | 06:25 PM
J-Bonz's Avatar
Sounds like your bad luck is giving me more time to get ours together quicker.
Jr.
J-Bonz is offline
Old 04-13-2008 | 06:26 PM
Full Force's Avatar
That is a l resort... I just assembled the shortblock...
Old 04-13-2008 | 06:27 PM
Full Force's Avatar
Jr.
I am leaving for work.. I will call you in a few...
Old 04-13-2008 | 09:30 PM
Turbojack's Avatar
On an old motor I had used helicoils and never had a problem gettting the bolt to start. When you screw the bolt in without the head on how far is it off compared to the other head bolts?
Turbojack is offline
Old 04-14-2008 | 08:19 AM
Full Force's Avatar
Problem is that the person who drilled it before I had the engine did it on an angle, so with the head on it will not start, it needs to be at 90 degrees.
Old 04-14-2008 | 12:07 PM
Registered User
First off, if it's a helicoil, it won't hold the torque you need. You need a thread insert. The difference is substantial. You can drill the block while assembled- go to a rental house and get a magnetic-base drill. Rent the jacobs chuck adapter too. McMaster-Carr will have a broad selection of different sizes of thread inserts as well as the taps and tap drills. Do not use the threadlock they apply to the insert- use Loctite stud locker. Myself, I'd use studs instead of head bolts
Chris Sunkin is offline
Old 04-15-2008 | 01:17 PM
Full Force's Avatar
My buddy that owns a machine shop gave me this... worked great!
http://www.timesert.com/html/bigsert.html
cliff3466
1
03-09-2008 08:10 AM
wolfdog
0
03-22-2007 08:49 PM
thanks_don
11-19-2006 08:24 PM
Maxx
17
10-01-2002 09:14 PM
lhousman
13
03-05-2002 01:47 AM
