-   -   Thankyou RM Builder (https://www.offshoreonly.com/forums/general-q/184617-thankyou-rm-builder.html)
CB-BLR 04-15-2008 10:48 PM
Thankyou RM Builder
1 Attachment(s)
I would like to thank Bob Madera aka RM Builder for specing the parts for my 540. I am really pleased. Dyno pull is with all accessories installed and blowing through Dana Marine Torque-flow exhaust.
Chris
Strip Poker 388 04-15-2008 11:11 PM
I like the HP #'s from 4800 to 5900. that should pull some good #'s.Congrats , Bob is pretty sharp on designing a cam. He goes that extra info, unlike most cam manufactures,they usually don't ask much:(
Rob:ernaehrung004:
Griff 04-15-2008 11:49 PM
The numbers look really good. I would think, prop it for 5400-5500rpms at wot as the spinning it 400 rpms faster for 10 hp isn't worth it.
CB-BLR 04-15-2008 11:56 PM
We were going for a very broad torque curve, and gave up some peak HP to gain it.
Chris
Pismo10 04-16-2008 06:45 AM
500 lbs of torque at 2500 rpm....awesome.
Strip Poker 388 04-16-2008 10:10 AM
but what does the 400rpm do for speed,mine was gaing 10 hp per 100rpm from 5800-6100,I prop it to 6000 for top speed, the capibilty doesent mean you run it there .
KAAMA 04-16-2008 10:19 AM
Originally Posted by CB-BLR (Post 2526807)
I would like to thank Bob Madera aka RM Builder for specing the parts for my 540. I am really pleased. Dyno pull is with all accessories installed and blowing through Dana Marine Torque-flow exhaust. Chris
Congrats!!! Those are some very respectable/impressive HP/TQ numbers with a "Manifold" style exhaust system!!!
KAAMA 04-16-2008 10:32 AM
CB...By the way, what size/brand of heads are you using? Also, was the engine dyno'd with or without sea pump, alternator, etc??? Was the exhaust system "wet" or "dry"? Just curious.
mrhorsepower1 04-16-2008 10:58 AM
:cool-smiley-027:
CB-BLR 04-16-2008 11:08 AM
Kamma,
AFR 305 CNC, Dana Torque-Flow exhaust - wet, vortex collector sized for 540, with sea pump, alternator, power steering pump, water pump. 9.6 compression, victor manifold, HVH 1 inch super sucker, 1050 Dominator, Jessel rockers, Morel lifters, Bob's cam.
Looking forward to putting it in the boat next week.
Chris
