Oil Filter Mess >
Oil Filter Mess
Oil Filter Mess
Old 02-20-2002 | 03:45 PM
dallas01
Question Oil Filter Mess
When removing the oil filer from a 7.4 MPI, how does one keep from having oil spill over the lip of the filter housing?? I put a bunch of paper towels under it first, but is there an easier way?? It's the only part of winterizing I find a pain.
Thanks for any help.
Old 02-20-2002 | 03:47 PM
formula31's Avatar
I think some of the guys are using zip lock bags. Sounds like a good idea.
formula31 is offline
Old 02-20-2002 | 03:57 PM
kook
But the filter is upsdie down (opening at the bottom), isn't it?
Old 02-20-2002 | 07:31 PM
Raypanic's Avatar
You could get a different oil filter bracket. I think teague has them. Mine hangs them with the top up.
Ray
Raypanic is offline
Old 02-20-2002 | 07:44 PM
Secretformula's Avatar
If your filter mounts upside down just poke a hole in it, this will let the oil drain bank into the oil pan.
Secretformula is offline
Old 02-20-2002 | 11:27 PM
outlawinil's Avatar
Default Oil Filter Mess
Hey dallas I have a pair of those 7.4L's with upside down filters. This has worked for me every time:
1. Run motor till warm then shut down.
2. Oil is leaving the filter after shutdown but i believe there might be an air lock in the filter so i SLOWLY loosen the filter enough to let air get sucked in but not enough for oil to get past gasket.
3. Let filter drain for awhile. (go have a beer)
4. Have a pan ready to sit filter in, remove filter
The main thing is to not get in a hurry. Let gravity work for you. I am not a believer in a hammer and a punch to put a hole in a fliter. Then you have oil running out both ends of a filter when you are dragging it over the side of the boat. Also you never can never be sure you didn't knock just a very small piece of metal into the filter and down into the motor.
outlawinil is offline
Old 02-22-2002 | 10:06 AM
dallas01
Thanks for the good advice! I appreciate it.
Old 02-27-2002 | 09:39 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I have the inverted filter on my HP500EFI as well. I use the grocery store platic bags, and surround the whole assembly as best as I can, including a rag. This is just a pain I have learned to live with. I also like to fill my new filter with fresh oil as I install it. My Chevy truck has the filter at a 90* angle, so this inverted boat stuff just adds another element to trying to keep things clean.
I may invest in a flipped filter assembly, but the filter now is just so easy to remove now.
In any rate, the boat is still much easier and cleaner than those few late '80s FWD Tech4 GMs that had the filter as an element in the oil pan. Has anyone ever changed these? The drain plug was actually a 4 inch disc, that you had to pull out, then remove the element, and you had a four inch hole where the rest of the 5 quarts were coming out of. I always ended up wearing half a quart, with another half a quart on the floor. Thank goodness GM stopped that madness.
Sydwayz is offline
Old 02-27-2002 | 01:19 PM
mxz800's Avatar
i have had the pleasure of changing the tech-4 filter what a mess! Even better when previous mechanic or owner cross- threaded the plug last change!! i use the plastic grocery baggy trick and works neatly for the most part. getting good and warm also helps and makes sucking oil out a couple minute job rather than a day adventure. i also always fill my filter with oil but not an option with the filter upside down.
mxz800 is offline
Old 02-27-2002 | 06:43 PM
E Z TERMS
a plastic garbage bag is the trick............just get it a little loose........put the bag under the filter.......pull it all the way up and dont snag it......then reach down into the bag and take it off.........dont drop it.........just lay it down and let the misc oil drain from the housing...........
EZ
