Oil Cooler passages >
Oil Cooler passages
Oil Cooler passages
Old 05-02-2008 | 12:35 PM
MnFastBoat's Avatar
Charter Member#157
Default Oil Cooler passages
I pulled mine out and the port one, has significant blockage
I am able to clean out all but one center passage
All hte outside passages still looked blocked, hard to get a wire rod in there to clean out.
Is it possible to still have enough water flow? Or should I look into replacing them?
Looks like I will be plumbing in some sea strainers
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 05-02-2008 | 01:41 PM
Wally's Avatar
Were doomed!
what are they clogged with? maybe put some muratic acid in there and let it do its job
-Wally
Wally is offline
Old 05-02-2008 | 01:44 PM
MnFastBoat's Avatar
Charter Member#157
Pebbles And not the Flinstone's Daughter either
Was able to get a lot of it cleaned out.
Wish our sionic machine at work was large enough, it does great vibrating things loose out of our steel filters
t500hps
07-17-2012 09:23 AM
J. Hordubay
13
10-02-2008 01:55 PM
31scarab31
2
02-29-2008 04:14 PM
slik22
Wanted
6
01-08-2008 04:13 PM
patrick22309
5
06-20-2003 05:53 PM
