Engine Dynos >
Engine Dynos
Engine Dynos
Old 05-03-2008 | 10:53 AM
Thumbs up
EXACTLY..........I had a crappy engine builder that talks a good game and "rebuilt?????" 2 engines for me 2 1/2 years ago. He had done a few drag cars, or so he says, and knew him somewhat. Well after installing/pulling engines 3 times and over a year not getting to boat for various engine problems, I said screw him. Took engines elswhere in 30 days had them back and in and no problems since. In fact last time the engines where out with "other" guy he had them dynoed, made 3 pulls, seemed ok. Then put the engines in run 3 hrs had water in oil from loose head bolts and no sealant on head bolts. So dyno is not fool proof but I would NEVER do another without it. A $5,000 job wound up costing me over $18,000. Now the guy has gall to sue me for $2,500 for micallaneous parts he says I owe him. Be carefull having an engine built in Hattisburg Miss. Sorry for sounding off.......I have court next month.
DO THE DYNO.....and have someone reputable do it and one that has experience with marine engines. I have learned some hard lessons.
team Tickfaw is offline
Old 05-03-2008 | 07:05 PM
Default dyno
Thanks guys allot of good advise/ experience, Ill get it dynoed in the next week or so .
redcorvetteman3 is offline
Old 05-03-2008 | 07:40 PM
offthefront's Avatar
Originally Posted by Pantera28-650HP
Just dynod mine with all accessories except power steering pump and with my headers. 1036 HP at 6000 RPM, 1004 Ft Lbs at 4400 RPM.
what a dog !!!
offthefront is offline
Old 05-05-2008 | 05:44 PM
737jetmech's Avatar
We dynoed one of my engines last week ... 4.280 bore x 4.25 stroke . 9 to1 compression , 731 crane hyd roller, oval port Edelbrock rpm performer marine (Ported). 489 cid made 614 hp @ 5600 torque peaked @ 4300.
your 496 should be real close to 625 depending on cam selection.
Bob
737jetmech is offline
Old 05-06-2008 | 10:13 PM
Thumbs up
Originally Posted by Kidnova
What Pantera28 said....
Plus, I'd say circle track is way closer to marine than drag racing is, due to long hauls with the engine "working" in both worlds. I'd call or stop in and talk to the dyno shops in your area and get a feel for them, and their experience with marine engines. And or their willingness to work with you relative to a marine application.
I'm having my engine dyno'd this coming Wednesday. I found a marine builder with a dyno, and considering our conversations he seems very detailed. I'm diving +,-185 miles ONE WAY, to have my engine dyno'd by a marine friendly shop. Marine dyno is that imprtant to me.
Good luck !!
I also agree. I drove 400 miles one way to do a complete marine dyno. Wet headers, my fuel system, etc.
Just an example we found that the pin connection for the knock sensor to the computer was not connected and may never have been, causing it to code and retard timing and messing with A/F ratios. This would have never been found without the computers.
RBeyer is offline
Old 05-06-2008 | 10:40 PM
Elite Marine's Avatar
Originally Posted by offthefront
what a dog !!!
I know, anyone have a good lawyer? Is there such a thing?
Elite Marine is offline
Old 05-06-2008 | 11:31 PM
Rebel_Heart's Avatar
I spent $700 on the dyno last season to set my engines up. Seemed like a lot at the time but glad that we did. Were able to play around with a lot of different options prior to placing in boat.
Rebel_Heart is offline
jayhawk261's Avatar
Dyno with the engine builder present so he can make the necessary corrections based on A/F and EGT data. You sig says that you're in Indiana. You may contact Pantera28-650HP about th shop where his engine is. I wouldn't think it would be too far away, and well worth running it in a shop with a guy who's business is tuning marine engines. That way, when it goes in the boat, you get to play rather than work.
jayhawk261 is offline
Old 05-06-2008 | 11:40 PM
I live in IL. and drove 400 miles. Can't speak for others but that was my choice after homework. Ask around and do your homework.
RBeyer is offline
Old 05-10-2008 | 07:24 PM
what should egt's be on the dyno,and is there a way to figure out vol ef% using bsfc and hp/torque numbers
dmaxx3500 is offline
PIT BULL
Velocity
3
10-29-2008 03:26 PM
Rebel_Heart
19
04-14-2006 01:30 PM
Clay Washington
01-16-2006 02:27 PM
dyno
66
07-27-2004 12:18 PM
