water pressure too high?? >
Old 05-07-2008 | 08:06 PM
monstaaa's Avatar
stats tend to make the exhaust headers run hot. if you have s.s headers like cmi for example, the constant expansion and contraction is not good for them.
assuming my water pressure is an issue, does this explain condensation in the oil, or just lack of heat build up?
as for this, no not psi, oil temp. remember water bolis @212 and steams @215. so no oil stat , expect some condensation
monstaaa is offline
Old 05-07-2008 | 08:15 PM
LZH
Dude - get some guages.
LZH is offline
Old 05-08-2008 | 07:26 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
Originally Posted by Ran-Dom 32
I do not have oil temp gauges, but I may hook up a temporary gauge to check
Can you get your hands on a Temp. Gun and shoot the oil filter after a hard run?
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 05-08-2008 | 08:20 AM
Ran-Dom 32's Avatar
great idea, My brother in law has a temp gun he uses for Powdercoating,
thanks for everyone's help,
BTW Monstaa, I am running CMI's , My plan was to run the t-stats until the lake water temps rises & then pull them out.
Ran-Dom 32 is offline
Old 05-08-2008 | 06:40 PM
Elite Marine's Avatar
You need gauges!!
Email me a list and I will help you out!!
[email protected]
Kirk
Elite Marine is offline
Old 05-08-2008 | 08:17 PM
If you want some gauges for testing and set-up, I think have some take-outs of water pressure and oil temp you can have for $15 ea. I agree on the need for oil thermostats, it is difficult to get oil temp high enough for long enough to keep the condensation out w/o extended high RPM runs.
In the Mid-West, the cool evenvings are likely adding condensation inside the engine every night after boating.
BenPerfected is offline
Old 05-08-2008 | 10:16 PM
Rebel_Heart's Avatar
I'm not running t-stats either. I was told there was a down side to running them, so I've been trying to get rpms up each time out.
Rebel_Heart is offline
Old 05-10-2008 | 09:25 PM
Blue by You's Avatar
FIERCE ALLEGIANCE
well, I added a pair of merc pressure relief valves, & a pair of 140 T-stats with 4 3/16 holes, went out for a test run & water temp was steady 130-135, oil looks good, & the valves were pumping water above 4 grand, next time out I will run a psi gauge just to verify my water pressure
What pressure are these valves? 30lbs?
Blue by You is offline
Old 05-11-2008 | 02:25 PM
Ran-Dom 32's Avatar
yes,
Old 05-11-2008 | 09:06 PM
This is what I'm running for water pressure. $30 and a little modification and ten times better that the Merc platsic valve. All bronze.
16lbs at 3800 rpm and 20lbs at wot. The installed pic is before I modifed it.
Attached Thumbnails water pressure too high??-dsc04645.jpg   water pressure too high??-dsc04636.jpg   water pressure too high??-dsc04627.jpg
Noise Pollution is offline
