-   -   water pressure too high?? (https://www.offshoreonly.com/forums/general-q/186007-water-pressure-too-high.html)
Ran-Dom 32 05-16-2008 08:26 AM
I also have the pressure relief valves, I will be doing some testing this weekend, I know the valves dumped @ 4000 & above, I'm expecting the pressure to be lower now with the lwp blocked off, I'll let you know
offthefront 11-24-2008 08:15 PM
RD .... what was the result of plugging the drives?
HotPursuit 11-26-2008 11:22 PM
Water under the valve covers and a raised level on the dipstick is two totally different problems. Like leaking headers,reversion,head gaskets,intake gaskets.
I dont run a stat and my valve covers are clean with no condensation. Cant say I have run in 45* water.
Knowing more about what # and temp would help.
32agitator 11-27-2008 05:33 PM
get rid of those t/stats it will not work correctly and the water on the dip stick is cause of no oil temp it will do this with cold intake water but in the summer months it wont
Jeff P31 11-27-2008 10:57 PM
How could you tell if any thing got fixed with no gauges ?????? :rolleyes:
