2006 496mag  3500rpm beep beep Why >
Old 05-08-2008 | 08:53 PM
Default 2006 496mag 3500rpm beep beep Why
at 3500 rpm beep beep,and the rev limiter kicks in,oil press 65psi,water temp 160,help
apexer is offline
Old 05-08-2008 | 10:03 PM
Ted G's Avatar
Had it happen to a friend with 525's. He had a bad neutral safety switch adjustment, computer thought it was in neutral and kicked in the rev limit. You can check it with a scanner or the Rinda program. BTW, it will not set a code.
www.cbpba.com
Ted G is offline
Old 05-09-2008 | 08:03 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
You may have a Exhaust manifold overheat conditon due to water flow. Especially if you have an aftermarket exhaust manifolds.. If you do, mostlikely The water flow is not balanced.. Also you didnt say if this happens in neutral or in gear. If it is in neutral it is just keeping you from over revving the engine..
In either event without having it scanned & monitored they are all just guesses...
Jamie / Lakeside Restorations
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 05-09-2008 | 01:09 PM
problem solved,must be in gear,neutral only goes to 3500 rpm
apexer is offline
Old 05-09-2008 | 01:21 PM
Knot 4 Me's Avatar
why are you revving the motor in neutral? there should be no reason to do this.
Knot 4 Me is offline
Black Tornado
Classic Offshore
42
04-06-2015 11:07 PM
Reckless32
54
07-03-2007 11:24 AM
fatdaddy
Baja
3
09-06-2006 10:57 PM
fatdaddy
09-06-2006 10:42 PM
Fast Shafts
General Racing Discussion
10
05-10-2003 09:01 AM
