check valve/anti-siphon >
Old 05-13-2008 | 05:50 PM
Default check valve/anti-siphon
Is there such thing as a high flow spring and ball checkvalve? Where do buy these things, I cannot find them anywhere. I would like to eliminate the one on my tank and put one after the electric booster pump, which is the highest point in my fuel system.
BGIII is offline
Old 05-13-2008 | 06:02 PM
Your local speed shop look in an EARLs catalog
Old 05-13-2008 | 06:04 PM
CPPerformance's Avatar
Not sure if there is such thing as a high flow version. We carry a 3/8 anti siphon valve for $9.99 (#620-1438). Give our tech department a call and see what they have to say.
Good Luck,
Brad
CPPerformance is offline
Old 05-13-2008 | 06:18 PM
I have seen the Earl's valves but they are not spring and ball from what I read.
BGIII is offline
Old 05-13-2008 | 06:20 PM
Good Luck,
Brad
Can you link that part. It shows nothing when searching for that part number on your website.
BGIII is offline
Old 05-14-2008 | 12:40 AM
Wink
Contact Imco. I believe they have a 1/2" check valve that is the largest I know about in the industry and it is what we require and recommend for any high performance marine engine over 525HP.
the smaller sizes can seriously restrict fuel flow and lean out the engine,when the engine is fuel injected and do serious engine damage under high loads.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 05-14-2008 | 06:14 AM
Registered User
Aeromotive. It's in the Summit catalog.
Chris Sunkin is offline
Old 05-14-2008 | 06:45 AM
those things are terribly restrictive, have had lots of issues with mine getting clogged with small peices of aluminum for what looks to be where they tapped the inlets...it's a wonder the engines would run at all with these things...Rob
ezstriper is offline
WARRIORMAN
05-17-2012 10:17 AM
f252tbird
12
08-12-2004 07:22 AM
zahndok
5
11-27-2003 12:07 PM
Breathe Later
Fountain
5
02-13-2003 08:28 PM
