-   -   Trim pump / Tab not working ? ? (https://www.offshoreonly.com/forums/general-q/186664-trim-pump-tab-not-working.html)
Cigret1 05-14-2008 09:43 AM
My trim pump is not working properly, when I hit the rocker switch it just makes a "clicking" sound and no movement on the tab.
The pumps should be working as they were recently rebuilt. Coiuld this be an electrical issue?
Any advice or recommendations greatly apperciated
Chris Sunkin 05-14-2008 09:51 AM
If it clicks but doesn't work, you probably have a bad solenoid. You can use one of those cheapo Autozone Ford starter solenoids to test- just swap it in place. If you don't mind being crude, you can jumper it with a pair of pliers- you'll scar up the pliers and the solenoid posts but that doesn't bother some people.
A test light will go a long way. There's power to one of the big terminals on the solenoid and when you apply power to the little terminal, it closes and transfers power to the other big rerminal. If it doesn't, it's bad. If it does, it still may be bad- just because it lights a bulb doesn't mean it's transferring enough current to the motor.
These solenoids are one of the items you need to have spares of on your boat. They do go bad and can ruin a weekend.
P.S. If they were recently rebuilt and they used an automotive solenoid, that just may be your problem. Auto solenoids aren't sealed- they don't last long at all in the wet environment.
Cigret1 05-14-2008 10:41 AM
thanks, i will pick up a new solenoid and hope its a chep quick fix.
if its not the solenoiod, you mentioned it could not be getting enough power???? any idea why that would be? poor connections? battteries? etc?
thanks again
obnoxus 05-14-2008 10:52 AM
try tapping the solonoid with the handle end of a screwdriver,,,,they carbon up on the tip end and cause what you are describing .and should get it working
Sometimes even pressing and releasing the switch a bunch of times quickly is enough to get it working.
Even if it starts working I would still get one to have on hand or just replace it ,,,,,,,,its not long for this world !!!!!!
Chris Sunkin 05-14-2008 11:04 AM
thanks again
With use, the internal contacts of the solenoid eventually deteriorate. They'll make a connection but with high resistance. This will let voltage at low amperage flow- like lighting a test light. Not enough to turn a motor.
Run_em_hard 05-14-2008 11:13 AM
Not tryin to hyjack but since we are on the topic I have a tab problem as well. Sometimes it will move and sometimes it won't. When it does it will shutter a little. Also, say its down and it won't go up at wakeless speeds I can get on plane and it will go up to pretty much level and no more. I figure its my pump?
C_Spray 05-14-2008 11:41 AM
Originally Posted by Cigret1 (Post 2557591)
My trim pump is not working properly, when I hit the rocker switch it just makes a "clicking" sound and no movement on the tab...
It could also be a blown fuse or tripped breaker in the power feed wire to the pump. Some installations feed the power to the pump on a separate wire from the power for the solenoid. There is usually an inline fuse close to the pump in most of the installations I have seen.
Chris Sunkin 05-14-2008 11:45 AM
Could be a solenoid, could be a weak motor in the pump.
Run_em_hard 05-14-2008 01:20 PM
I will switch my pumps and find out...
Cigret1 05-16-2008 11:08 AM
Had a chance to play with the pumps. I inspected all the solenoids and they appear to all be new. The one pump for the drive was making the clicking sound as well, a few whacks on top of the pump and it is now working and sounds normal. So i tried the same on the tab pump, only makes a weak sound while you whack it. im guessing that motor is shot and will need to be replaced.
The drive pump seems to be working fine as of now, while im in there do you think it would just be worth replacing both, so i dont end up out in the lake whacking the pump?
Thanks for all the help
