-   -   Drive alignment on triples (https://www.offshoreonly.com/forums/general-q/186717-drive-alignment-triples.html)
grand-illusion 05-14-2008 08:40 PM
Looking for input on the best way to set drive alignment for a 50 Hustler, triple engine, #6 drive boat. I currently have them set dead parallel. Would I be better off setting the outside drives towed in, out or leaving them parallel? If so how much on the toe? Thanks.
trips2win 05-14-2008 09:20 PM
good question i have tried dead even and out an 1/8 found steering all over the place and ended at 1/8" toe in
MOBILEMERCMAN 05-14-2008 09:34 PM
The pair that swing in are trying to come together try them at 1/8 to 3/16 toe in. the pair that swing out set them 1/8 to 3/16 toe out.
Under load you want them parallel.
My 2 cents
