online water impeller tutorial? >
Old 05-20-2008 | 05:49 PM
Default online water impeller tutorial?
Havent done one of these in a few years. I was wondering if anyone knows of a place online that shows the part numbers I need and how to do it all properly.
Also, how often should the thermostats be changed??
Im tryin to get my yellow bastard back on the lake this weekend!
waterboy222 is offline
Old 05-20-2008 | 08:44 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I always refer to BAMS site for Merc part numbers and exploded views.
http://www.mercruiserparts.com/mercruiser_parts.asp
T-stats. Never knew of a replacement schedule, other than replace if in doubt or bad.
US1 Fountain is offline
Old 05-20-2008 | 08:59 PM
You can buy all the parts you need a kit for whatever you have.
http://boatfix.com/bykeywordmerc.asp...kit&texttype=2
Griff is offline
Old 05-20-2008 | 11:31 PM
bring her over and we will show you. you can do it yourself in my shop if you like. very busy weekend so you may get wait listed.......bring beer and see the front of the line.
mr.boat is offline
Old 05-21-2008 | 10:54 AM
outstanding, thanks scott. Ill give ya a shout after work today and see whats up for tommorow
Old 05-21-2008 | 02:51 PM
Downtown42's Avatar
this is the best thread I've read on the subject.
http://www.teambajamarine.com/forum/...ead.php?t=6560
Downtown42 is offline
Old 05-21-2008 | 03:03 PM
offthefront's Avatar
the easiest way I think is to pull the whole pump with the bracket off ...put it in a vice and remove the plastic housing .....6 bolts? ... remove the old impeller ...inspect the wear plate and inside of the housing ....if its been more than a cpl of years you might want to order the whole kit ( impeller ,housing,wear plate,bolts, orings) .... take a big pair of needle nose pliers and twist the impeller into the housing ...clockwise ..(doesnt really matter it will flip) ...bolt the housing on the pump/bracket ....then install on the motor ....m
offthefront is offline
Old 05-21-2008 | 03:42 PM
A t-stat kit with tstat and gaskets should run $15-20 at local boat store; pretty cheap and easy to do if you've already got the wrenches out. The impeller & housing kit should run $65-100 at the same place.
Another good online pictorial:
http://www.speedwake.com/upload/show...threadid=18967
I have '91 motors, so v-belt arrangement. Instead of pulling any of the brackets or trying to loosen the belts, I loosen the pump mounting nuts and the pulley bolts enough to get the belt off. Then remove the pulley, then the pump. I can't remember whether I prefer loosening the hoses before or after, but if you can get to them, it's usually better to loosen stuff while it is still attached.
Make specific note of which bolts go where, there are two different lengths. A little of your favorite water based lube and you can twist the impeller in the new housing by hand.
Installation is the reverse of removal.
handfulz28 is offline
Old 05-21-2008 | 08:38 PM
see what some people think about the run dry impellers. There was a thread on this some time back but I don't remember the out come.
B one is offline
Old 05-21-2008 | 11:19 PM
c_deezy's Avatar
Just remember to lube up the vanes. Dish-soap works good, then you don't have to worry so much about getting the vanes the right way.
c_deezy is offline
Downtown42
4
08-04-2007 01:43 PM
mats
14
10-20-2006 10:42 AM
LostinBoston
1
02-19-2006 07:00 PM
gripit
5
12-19-2004 09:35 PM
Kirch
07-15-2002 12:31 PM
