-   -   Stock 502 Exhaust leaking (https://www.offshoreonly.com/forums/general-q/187541-stock-502-exhaust-leaking.html)
T-Mone 05-31-2008 12:47 PM
Originally Posted by txriverrat2001 (Post 2575508)
Toss 'em - get the VISA and get aftermarket. The ole saying is "If they're leaking on the outside... they're leaking on the inside" which leads to big $$ if you don't address it quickly.
has anyone tried to run the water out of the thermostats directly out the back of the boat instead of running it through the headers, making it dry exuhast.
txriverrat2001 05-31-2008 12:55 PM
You're kidding right??? 1) it would melt the exhaust hose in .... say 2 minutes?? 2) Carbon Monoxide would fill the hull 3) It would evetually catch fire ....
Don't even think it......
Chris Sunkin 05-31-2008 01:02 PM
No water crosses at the head-manifold junction.
If they leaked there, they're rotting through everywhere. I know the manifolds aren't cheap... but price a set of new 502's. Cause that's what you're going to need when they leak internally and destroy your motors.
You got lucky.
T-Mone 05-31-2008 01:11 PM
got it..
offthefront 05-31-2008 01:11 PM
Originally Posted by MnFastBoat (Post 2575497)
Thanks for the upgrade ideas, trust me they have been in the back of my mind for over 7 years :)
However the $$ is just not there to replace exhaust on a set of twins!
you got the money to rebuild both motors? just seeing the pics ... and you say 7 years ? replace em ....m
Griff 05-31-2008 02:04 PM
As said before, look for some 496 take offs. They are better, lighter and won't break the bank.
MnFastBoat 05-31-2008 04:22 PM
Nope No Visa's allowed in my household!!!
They are not leaking internally, the 7 years still has less then 230 hours on the boat!
It is not the manifold that is leaking, it is the plastic plug on the back side of it!!
So thankfully it was a $6 part causing all this commotion :)
Well and then the cost of new gaskets :(
But all is well and that is the way it should be
btw, I have been told many times that 496's are not a direct replacement for the 502's
They do not line up with everything. Yes they can be done, but why?
Reckless32 06-01-2008 10:51 AM
The 496 replacement thing has got me curious. Not that I have a 502, just want to generally know what it entails to do it?
Also a question on exhaust manifolds in general....Do you use any type of gasket adhesive when replacing a new gasket?
Griff 06-01-2008 01:06 PM
No adhesive is needed. Many of the gaskets have a graphite or similar surface to get a good seal.
MnFastBoat 06-23-2008 07:05 AM
All is great
Had the exhaust back together yesterday and running on the hose. NO water leaks!
It "was" the plastic bung fitting on the back side of the manifold.
When I took it out it was way to easy and you could see the issue.
Will be on the water this weekend, Mother Nature permitting :)
