454 Mag MPI
Old 06-05-2008 | 11:59 AM
Default 454 Mag MPI
270 hours, and runs fine. but every once in a while when i start it, it studders and has to be restarted. well it would not start back up then, but if you let it set for 10 min, it works again. any ideas? am i missing something, its multi ort injected, so you can't flud it....
mittens is offline
Old 06-05-2008 | 12:01 PM
obnoxus's Avatar
Charter Member #1171
Sticky IAC valve?
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 06-05-2008 | 12:02 PM
obnoxus's Avatar
Wait,,, back up a minute,,,,, is it when its cold or warm?
obnoxus is offline
Old 06-05-2008 | 01:51 PM
its only done this 2 times,
first time, i left it at the dock that night, and came back that morning to put on traler... started fine, moved across marina, and parked at gas dock while putting trailer in water = then would not start. 10 min latter and some hitting the key, it runs like nthing happend.
second time, drove up river a ways 5-7 miles. floated, and had to move a time or two int he next 2-4 hours. so just crank up and move out away from banck and kill it again. after about 3 hours it did it the second time. by the way. My boats name is OBNOXIOUS.
mittens is offline
Old 06-06-2008 | 09:05 AM
No one have any thoughts?
bump
mittens is offline
Old 06-06-2008 | 02:54 PM
I have the same engine and mine does that every once-in-awhile. It acts like it's flooded. All I do is stick the throttle in the flooded start position (about 1/2 throttle out of gear) and then crank, and it starts right up Just got to yank the throttle back quick when it catches to keep it from over-revving
suntimes is offline
Old 06-06-2008 | 04:54 PM
I will try that. I have tried to pump it like a carb boat to see if it helps, but sounded like it tried but then nothing. but next time i will try.
mittens is offline
mg503
Baja
14
04-03-2013 04:50 PM
cliff3466
1
03-09-2008 08:10 AM
wet_rat
09-26-2007 12:01 AM
MC-BOYS
7
07-11-2006 02:15 PM
Elite Marine
Pantera
0
08-18-2004 07:48 AM
