Mercruiser Tunderbolt distributor
I have no spark on one of my 454 mags. I swapped the amplifier
and coil from one engine to the other. Still no spark in the problem one, I assume it is the distributor,i.e. the magnetic pick up sensor. All of the parts I removed work fine on the other engine. Anyone have one of these that they would be willing to sell? Thanks for the time. Quikdecision. |
Swap distributors and see if it follows....
If you still need one i have one that a "buddy" had me buy for him thinking he needed one and turned out it was a bad cyl in the motor so now i have this collecting dust! If you want it you can have it for what i paid for it $60 + shipping.... Its complete with the cap too...i have no use for it |
Wally, sent you a PM.
$60.00 is the standard merc price for a new pickup. there is a procedure for testing the system.
I chased the similar problem this weekend. Ended up being a broken wire coming out of the distributor and into the loom. If I recall they are both tan one with a red stripe and one with a blue. Use a ohm meter/volt meter and check them both with the key on and compare it to your other motor. Mine also had a fuse coming off the starter up into the loom.
Test procedure:
http://www.marinemechanic.com/site/page251.html |
Quik order out the pick up , had the same prob .If you want the test procedure out of the merc manuel to be 100% positive p.m. me your fax # and i'll shoot it across it'lll take ya 10 mins good luck
Check for 12v on the + side of the coil (purple wire) with the key on.
Hey Everybody....
Thank you so much for your responses. I ohmed out the wires on the distributor, just as TSSTEPH had suggested. I had a broken wire. I took pics, too late to load tonight. Thanks again everyone. Quik |
flat line
hey anybody have a problem with sensors telling the t-v to flat line at 4000rpm, can i just unplug the knock sensor and jump a wire to get to winterizing time??
| All times are GMT -5. The time now is 07:26 PM. |
