700sci oil filter >
700sci oil filter
700sci oil filter
Old 06-29-2008 | 02:07 PM
Hydrocruiser's Avatar
Arrow
This is another fantastic oil filter that is "overbuilt".
Excellent flow and filtration...AND good at higher oil pressures; very tough build quality. Similiar to the Mobil-1 and Amsoil filters that use newer generation cellulose. Great filters expecially for synthitic oil for extended use.
I still personally use M-1 oil filters as they are easy to get off the shelf. I use either M-1 V-twin or Redline these days along with some Amsoil Series 2000 products.
I was PM'd thought I would share the info.
http://www.knfilters.com/oilfilter.htm
Hydrocruiser is offline
Old 06-30-2008 | 12:48 PM
ROADHOG's Avatar
Just talked to Wix Filters and they suggested that 51061R is meant to be used only once and for RACING only. The TECH person stated that this filter only filter's at 61 microns.
I'm more confused now than when I started too ask questions!!!!
The reason I called Wix was to ask why their filter only had 6 drain back holes and the HP4 had 8. Along with having 2 more holes they were larger in diameter.
ROADHOG is offline
Old 06-30-2008 | 02:48 PM
Arrow
There are non-detergent racing only oils that are used with a high flow lower filtration oil filter for one "race" and only one race.
Unless all you do is race you don't want that kind of oil or filter.
Old 06-30-2008 | 04:07 PM
ROADHOG's Avatar
So the answer is do not use the Wix 51061R unless you are racing. This is not an everyday filter with conventional oil?
ROADHOG is offline
Old 06-30-2008 | 07:44 PM
Arrow
Wix actually lists all their filters on the web page below page as "Principally for Racing". A good number do not have anti-drain valves....I am not an expert on Wix Filters.
I use Mobil-1 oil filters. Mobil 1 touts as having 98% single-pass particle filtration at 10 to 20 microns, and multiple-pass efficiency of 95% (vs. 80% for the average filter).
As far as Wix goes:
http://www.wixfilters.com/filterlookup/racing.asp
I did some additional research and the 51061R Wix Racing crosses with the following:
Volvo # 835440
MerCruiser #'s 14957, 35-802885T & 35-866340Q03
Wix # 51069 (Racing Only)
Napa # 1069
Purolator # L20049
Mallory # 9-57801
Fram # PH30
Sierra #18-7824
Old 06-30-2008 | 08:11 PM
Default 700 Filters
I do not see any cross for a Merc 35-840634K01. This part # is on the filters that came with my motors from Merc. what suggestions??
fossil fuel is offline
Old 06-30-2008 | 08:19 PM
Arrow
I can't find anything on that part number..sure it is correct?
What kind of engine/year?
Old 06-30-2008 | 08:46 PM
aTX427's Avatar
It is actually a HP6 size filter.
aTX427 is offline
Old 06-30-2008 | 09:04 PM
Arrow
fyi..
Frams HP Series filter is just for performance and racing use. This spin-on filter can trap particles as small as 15 microns smaller than the 20-40 micron-sized particles that cause most engine wear. The filter has an anti-drainback valve. Maximum flow rate is 10 gpm and maximum operating pressure is 200 psi.
Now these are $20/ea and I suspect a decent filter vs. the Fram $2.99 filters>>?
Old 06-30-2008 | 10:35 PM
I was told this filter does not have a drainback valve. Makes for less of a mess whan changing. Punch a small hole in the top and wait a while... remove with no mess. I checked the # it is correct..Thanks..700's w/NXT's
