Dual Ram Imco hyd. Steering ..... air in System ?
Hello all , when i remove the motor last fall , i disconect the power steering pump (maybe its where i insert air in system), and now the last two time i use the boat i always have mess in the bilge of hydrolique oil , the reservoir over spill by the cap , what i made so far is with the drive on and motor not running , grab steering wheel and turn until it begin to be hard to turn , but no luck , today i remove the drive and redone the steering wheel ...do you think i will finally stop my mess in the bilge ....sorry the search feature not working for ...this is why i ask ....sorry for my bad english ...if you don`t understand feel free to ask
Regards Christian |
Sounds like the resevoir might be overfilled ?? Make sure to check the level on the dipstick. It should be only about 1/2 full in the can.
Originally Posted by Smitty
(Post 2589660)
Christian |
Is it possible that the two hoses to the pump got reversed when they were refitted? Although, normally the return hose is a smaller diameter and is only a push fit.
The system shouldnīt be able to swallow more air (and therefore displace more oil). The air bubbles normally leaves the sytem when they pass through the reservoir. To bleed the steering system, when refilling you should run the motor at idle and slowly rotate the steering wheel from full lock to full lock maybe 5 - 10 times. Avoid overfilling the resevoir (leave space form decompressing air bubbles to expand the volume of oil), but top it up as it starts to drop. Hope this is a help to you. Why did you have your 525 out? |
Now I just reread your first post. If you rotate the wheel (which should be difficult to do when the motor isnīt running, as you posted) you will be compressing any air bubbles that are in the steering circuit, and because the pump circuit isnīt running (with the motor) the bubbles will stay in the system. Bleed the system WITH the motor running, and you should be fine!
Originally Posted by Wild Card 09
(Post 2589888)
Thanks again to have take time Christian |
| All times are GMT -5. The time now is 07:59 PM. |
