Tired motor ?
last year I had to tune turn the idle up because it would barely run at 650 rpms. Then it would not shift out of drive being that I had it to high, I turned it down. Now it has a harder time starting at such a low RPM. This motor is a 1986 in a older 23 Powerplay. I am thinking that the motor may be getting tired... or really just the cam ? it does not burn any oil and a few years back it had some oil pressure issues and I thougth it might be the gauge and got it back to the marina and it was the oil filter. That was 2002 ?
any ideas ? Thanks, Steve |
Engine? Carb? Setup would help.
Carb rebuild time? power valve? Does it run good when off idle? have you lost performance (besides idle) |
Yes, carb rebuid a couple of years ago.
350- 260HP New cap, rotor, wires and plugs in the last 2 years. this thing use to crank 4800 now maybee 4200 RPM ? |
do a comp test.... plugs should be done at 50 hrs.....
Do a leakdown test. Might be time for a valve job.
ok, at what point do I just yank it and put in a new one ?
if the cam is shot and it needs a valve job ? maybee the cam is ok?? keep them comming ...the advoise that is. thanks, Steve |
i have a 454 just rebuilt i will sell you....
would it even swap right in with a Alpha ?
what year and model 330HP 365 HP 420HP |
Originally Posted by powerqrudy
(Post 2591858)
what year and model 330HP 365 HP 420HP Have Exhaust (cmi)...new 454 460 ci holley carb 830 rpm performer intake steel crank 4 bolt srp pistons dimple rods crane cam (134241) 534/553 lift 226/236 |
Sounds like it might have a vacum leak. That is usually the case with and idle problem like that. The carb might be wore out. Throttle shafts worn? causing a leak maybe. but look into that.
| All times are GMT -5. The time now is 09:21 PM. |
