-   -   reversion or manifold problem (https://www.offshoreonly.com/forums/general-q/189435-reversion-manifold-problem.html)
ak 06-22-2008 06:57 PM
hey guys,
I took my emi thunder manifolds off today after putting about 4.5 hours on my new 509ci engine,i took them off to remove my valve covers to readjust my valves.When i removed the left side manifold from the head,i noticed little water dopplets in each exhaust runner on the manifold and also a "clean"spot where it looks like pressured water was,i removed the other side and it was dry and carbon black looking,no problems.We tested the manifold for a internal leak and as of right now there is no signs of a leak,i did buy these used and i would say they are 5-6 years old,what is this?not reversion i hope because the other side is dry,cam specs are 606 and 617 lift,236 and 244 duration on a 110 intake center line,it is a custom grind from comp,please lets hear some input?
1BIGJIM 06-23-2008 09:43 AM
Ok I will throw in my 2cents. If only one side has water drops I would look at the the manifold.
Reversion - how does it run at idle. Does it load up. It easy to tell. What color is the oil.
I had to change a 110 centerline cam once because of reversion.
Thats to bad you have to remove the exhaust to get at the valve covers. I am running IMCO manifolds with tall valve covers and can still take mine off without removing anything.
jeffswav 06-23-2008 07:40 PM
I have removed my valve covers before without removing the manafolds. You need a 1/4" swivel drive. One thing that helps is I installed studs instead of bolts. I have the EMI exhaust and have had great luck with them. Do you have long or short risers? Short risers with that cam will give you problems. I have the long risers, with that I had to remove the silent choice. Good luck with your problem.
B one 06-23-2008 09:01 PM
If it looks like a leak, and it is wet like a leak, it's a leak.
The clean area is the dead give away water turning to steam and it is steam cleaning your manifold at that spot.
DORaymond 06-26-2008 06:53 PM
Although I have never seen it discussed here, I have had reversion issues when I have had valve train trouble allowing the valves to go out of adjustment (loose due to slightly bent pushrods from valve float). Corrected valve train trouble, and upon re-inspection, signs of reversion disappeared.
