Spark Plug electrode burned.  Any ideas? >
Old 06-24-2008 | 03:16 PM
got to be real bad lean !!! what type plugs and ignition ?
ezstriper is offline
Old 06-24-2008 | 05:27 PM
Ona-Mission's Avatar
Thanks for everyones advice. I have changed all the plugs, and just took it to the local motor guru to get it checked out. Like others here he suggested that timing could be a problem, and that a compression test would be a good idea. He believes that although anything is possible, there shouldn't be any major damage. I'll post the results when I hear back.
Ona-Mission is offline
Old 06-26-2008 | 06:43 PM
DORaymond's Avatar
Spark plugs that are not tightened properly do not transfer heat to the heads correctly and can overheat. Proper torque on spark plugs is more important than some folks realize.
DORaymond is offline
Old 06-27-2008 | 01:40 AM
articfriends's Avatar
I have seen spark plugs loosen in a small block circle track motor and snowmobile motors that were detonating,I personally tightened them correctly. I haven't seen bbc plugs loosen but what would make it any different. I think you are too lean and it is detonating,you probably just can't ear it,Smitty
articfriends is offline
bleachers
Do It Yourself, Boating on a Budget
3
07-25-2008 09:59 AM
rangerrick63
06-10-2007 08:15 PM
Tantrum
07-16-2004 05:41 PM
RebarBox
05-31-2003 08:39 PM
Jana
2
07-29-2002 02:45 PM
