496Ho, need some help? >
Old 06-22-2008 | 09:51 PM
288sunny's Avatar
Emerlad Coast PwrBt club
Default 496Ho, need some help?
I just got the boat all put back together and trying to figure a few things out, boat seem to run good, water temp was around 160 ( did rise up when coming off plane) and oil pressure was around between 20-40 psi.. I dont have a oil temp gauge but wish i had one right about now.. How hot should my oil filter be, when i put my hand on it, it was pretty hot, after a couple of seconds i had to pull my hand away..
I also have some marks on my coolant res. that use to judge the level in my tank, and after this trip i noticed the level was higher, which means either pressure, or sea water, how could i confirm one or the other? Im guessing if it is sea water, that would mean my heat exchanger has a problem?
The last thing im looking into is, again my temp seemed to be good, however at idle i have steam coming out the exhaust, this happens even when i fludh the motor. That to me means the exhaust is alittle to hot, but im not sure how i could improve the water flow anymore?? any thoughts?? ideas
288sunny is offline
Old 06-23-2008 | 08:07 AM
288sunny's Avatar
Default help
anybody out there shed some thoughts, ideas?
288sunny is offline
288sunny
47
02-26-2007 09:32 AM
dkehzrd
03-12-2006 11:50 AM
dmann
3
05-07-2004 04:19 PM
Bajaforce
0
09-08-2003 09:28 PM
CFD5
07-02-2003 06:41 AM
