-   -   525sc - what thermostat and engine temps (https://www.offshoreonly.com/forums/general-q/189920-525sc-what-thermostat-engine-temps.html)
Rambunctious 06-29-2008 09:28 PM
what thermostats do you run in the 525sc, and what temps do you see
I replaced my thermsotats this year. actually had first run of the season yesterday ( I know, michigan sucks!!)
anyway. temps seemed higher than i expected ( 170? on starboard engine, 160 on port)
I may switch the stats to see what happens, but ordered what mercury said on Bam's site, maybe there was an upgraded ( lower temp) stat recommended than the original 1995 part number??)
thanks
Ramb
Rambunctious 06-30-2008 12:12 PM
TTT
griff?
bueller?
DRIPPINWETII 06-30-2008 12:21 PM
Originally Posted by Rambunctious (Post 2607652)
TTT
griff?
bueller?
140's
Rambunctious 06-30-2008 12:25 PM
that is what i assumed i bought....
what running temps do you see.
Ramb
DRIPPINWETII 06-30-2008 12:31 PM
Ramb
150-160
I am not running any now that I upgraded to the Holley 250 Blowers with crossovers.
Griff 06-30-2008 01:27 PM
Stock is a 140* Tstat. Mine always ran 145-155 on the guage.
Rambunctious 06-30-2008 02:22 PM
I thought mine were running 150/155 also last year ( again, very few running hours to remember for sure)
i will go buy some 140s again jsut in case
and flush the seapump plumbing too ( since this boat is 100 times easier to do than my 272 formula was :o)
thanks
Old Navy 06-30-2008 03:14 PM
I also run a Merc 140 deg stat with 3 small holes (1/8") drilled in it. Temps are always 140-150 while running.
Rambunctious 06-30-2008 03:39 PM
3 small holes in the thermostat itself, or the bypass area of the gasket?
Old Navy 06-30-2008 04:17 PM
T-stat itself.
