3/8 hose
Old 07-07-2008 | 10:42 AM
bcfountain's Avatar
Registered User
Default 3/8 hose
how much horsepower can a 3/8 diamerter support at 4-6 psi on gas?
bcfountain is offline
Old 07-07-2008 | 10:48 AM
between 4 and 500 BUT the pump has to be able to produce the volume vs time ( gals per min ) that the motor is going to use... which, for the sake of discussion is generally something more than 60 gal per hr.
in the end, people talk about using 1/2 to be safe all the time which i suppose is cheap insurance.
stevesxm is offline
Old 07-07-2008 | 11:44 AM
Default Hp With 3/8 Id Hose
No More Than 450 Hp.
Jb-fse is offline
Old 07-07-2008 | 11:46 AM
axapowell's Avatar
Where To
Look at what Merc uses for their 600's....3/8".
I'm using 3/8" on 650's....Stock Merc (HP500) pump..NO Problems.
Dave
axapowell is offline
Old 07-07-2008 | 01:50 PM
I am using -6 line (3/8') on 780 HP and hold 5.5-6.0 lbs at WOT.
If you figure a 3/8 line will flow approx 60 GPH, then a 3/8 line will support 800+ HP at .5 lbs per HP per hr.
If you can easily re-rig with 1/2" line, I suggest it so you won't have to listen to the chatter on OSO that it won't work
BenPerfected is offline
Old 07-07-2008 | 01:53 PM
My 525SC had 3/8 and was bumped up to 550hp+ and had no issues.
I would also get a pump that will keep fuel psi at 6-7#
Griff is offline
Old 07-07-2008 | 03:08 PM
bcfountain's Avatar
Registered User
Default thanks
thanks for all the input.it gives me food 4 thought on a problem i have had for a long time.
P Offshore
05-19-2007 02:28 PM
dogghouse
07-31-2006 07:51 AM
SmallPP
0
02-23-2005 05:56 PM
Raypanic
1
01-24-2002 07:46 PM
