Originally Posted by RunninHotRacing158
(Post 2619620)
:eek:read a plug from that pic... Now thats funny
Did you find any metal in the intercooler ????? Ours got caught in the cooler fins ... |
Any chance you got a pic of your rotors in your blower? Where did you get it rebuilt? I might have a similar issue.
I do have pics...just not at work with me. I will post some when I get a chance. I was told that these blowers are adjusted by shimming the gears in and out and that it does not have a robust fastening system to keep the rotors in time. I have not torn the blower down yet to see what came out of adjustment. I am new to forced induction so somebody chime in if I was told wrong here.
That would be great. Thanks. The guys at The Blower Shop seem to think I lost a bearing and that is what caused the rotors to hit and get all ground up.
My rotor hit the top of the case on the cross bar that connects to the opposite case side. The gooey aluminum wadded up on the one rotor and created a wedge locking it up.
Anybody know if they can rebuild a blower in this state? Can the case be repaired? Can the rotors be repaired? Is yours a Weiand 256? |
Originally Posted by JRider
(Post 2618455)
On the 4th my blower self destructed rotors hitting the case. What happens the shavings that go through the motor? I would think on a NA motor the cam overlap would blow them out if the did not melt in the chamber. How does this work on a Blower motor? Should I be worried in any way? Maybe do a compression check?
JRider I've seen things as small as a pencil tip destroy an engine, and have watched items the size of a washer get spit out of the exhaust without hurting a part. For the cost of a set of gaskets to take the engine apart and inspect it, it's not worth not doing. |
(Post 2667007)
Anybody know if they can rebuild a blower in this state? Can the case be repaired? Can the rotors be repaired? Is yours a Weiand 256? Hey BIG Daddy Darrin Meyers Performance is in Mich and has done my 1471s all the way down to the 177s talk to Brian at 269-428-5070 last i talked to him the were coming out with there own line of marine blowers this fall and was pretty reasonable good luck |
So...after the blower siezed, popped the belt off and it would not go past 800rpm in gear! I had the slowest tri-tune on the lake! Idled back to the sand bar, cracked a beer and wrote the day off. A guy walks up and says he has a W256 straight from merc on his garage shelf! $1100 and its yours...showed up on the marina dock the next morning and was out on the lake july 4th by 11am. The blower still had blue masking tape on it from merc. Mailed the guy a check the next week!
Originally Posted by RumRunner
(Post 2667035)
Take the engine apart!!!
| All times are GMT -5. The time now is 03:09 AM. |
