Need some help...here are the symptoms >
Old 07-12-2008 | 11:02 AM
Default Need some help...here are the symptoms
Went to start the boat and the batteries were dead (thats never happened before) jumped it and fired it up. Idled OK for a few seconds then idle went up to around 1500 (from normal 800-1000). Boat has a MSD 6ALN box with a MSD distributor. Let it run for about 15 minutes and dropped the idle down to what it used to be. Then I revved it a couple times and the idle went back up to 1500ish. I am about pull the plugs and see what they look like. Last weekend we were out jumping swells in it so I am also thinking that maybe one of the weights in the distributor let go. Actually before I take a look at the plugs I will probably look at the distributor. Let me know if any of you guys have any other suggestions.
bruin_d is offline
Old 07-12-2008 | 03:08 PM
Thanks for all of the great help...
bruin_d is offline
Old 07-12-2008 | 05:06 PM
how about doing a few of the most basic things yourself first like disconnecting the cable and making sure the carb gets back to the stop and the 10 or so other things like that before you start looking for a remote diagnosis based on absolutely no provided hardware specifics...
not everyone is kreskin , ya know.
stevesxm is offline
Old 07-12-2008 | 05:40 PM
I fixed it, distributor was slowly turning while the motor was running. Did you ever think that maybe I already did the "basic things" first tough guy?
bruin_d is offline
Old 07-12-2008 | 08:53 PM
Registered User
Saturday at noon in mid-July and you feel the need to get snotty that the world isn't sitting on OSO waiting to offer tech info?
I don't think I'd take it personally... we do have lives- well, some of the others do.
Chris Sunkin is offline
Old 07-13-2008 | 10:26 AM
well put.
ubet28 is offline
Old 07-13-2008 | 12:24 PM
frankly, based on your question, it never occured to me that you might have done anything other than whine.
stevesxm is offline
Old 07-14-2008 | 02:47 PM
jhiguy377's Avatar
ditto
jhiguy377 is offline
klmken
12
05-21-2006 05:16 PM
