twin 496 diffrent rpm's >
Old 07-16-2008 | 07:35 AM
thank you I will try that this week end,when I rotate the props what can I expect the boat to do and can I run it wot?
sonic28 is offline
Old 07-16-2008 | 09:00 AM
causin trouble's Avatar
Default same issue on my 2001 353 fastech
I just re-installed my motors after repowering the 496 ho with upgraded pistons 5 lb procharged etc,etc,etc
I am not sure if I still have the rpm difference like before doing the upgrade ...my feeling always was that the fuel pump or screen was getting clogged or blocked at higher rpm I had a 200-250 rpm difference mine was at wot or above 4600rpm I know in the past 496 motors had issues with debris clogging the fuel pump because the filter is after the pump..496 have 2 fuel pumps 1 (boost pump l/s of engine in front of fuel water seperaotor)that draws the fuel from the tank and 1 that is on the r/s of engine which sends fuel to the rails.
causin trouble is offline
Old 07-16-2008 | 10:11 AM
It will handle differently, spinning out vs. in... overall slower, but you should be able to see if the lower rpms follow the props, or remain the same.
Carder
PS: did you check the magnets in the upper drives for any bearing or gear material sticking to them?
Carder is offline
Old 07-16-2008 | 10:53 AM
are we sure you just don't have a cam lobe leaving town ? or as happened before here, that you didn't get the firing order wrong on that motor somehow before all this started...
stevesxm is offline
Old 07-16-2008 | 12:53 PM
Angry
the firing order is fine when I replaced the plug I do one at a time also use a scope to see how it was firing.
sonic28 is offline
Old 07-17-2008 | 09:31 PM
jbraun2828's Avatar
could be a bad throttle cable, they can get stretched over time
jbraun2828 is offline
Baddogg
Pantera
3
02-10-2008 02:48 PM
berns29scarab
Pantera
6
11-22-2007 08:00 PM
Rocko C
7
08-27-2007 12:07 PM
BZ
11
07-18-2005 04:41 PM
WHOSNEXT
Pantera
2
08-25-2004 06:27 PM
