oil help
Old 07-15-2008 | 11:24 PM
some lucas oil treatment would help
5050 is offline
Old 07-16-2008 | 07:21 AM
Knot 4 Me's Avatar
Another problem is only 4.5 quarts in the 6.2's.
Knot 4 Me is offline
Old 07-16-2008 | 07:42 AM
thanks_don's Avatar
thanks everyone for your input.
thanks_don is offline
Old 07-16-2008 | 11:21 AM
hunster's Avatar
My 350 mags do the same. 40-60 under load running. After a wot blast can drop to 10-15 @ idle. As oil cools idleing around , comes back up @ idle. Seemed to be worse during initial 20-40 hours and does not do it as much now that the "break in" is done. Running merc oil for warranty sake. No oil coolers on my setup either. That may be a something to consider.
hunster is offline
Old 07-16-2008 | 12:57 PM
If you purchase a quality oil, you don't need an oil treatment.
Ken
minxguy is offline
Old 07-16-2008 | 04:42 PM
Hydrocruiser's Avatar
Lucas is a good product but probably not your answer.
Hydrocruiser is offline
Old 07-16-2008 | 04:43 PM
Arrow
In general what causes low oil pressure??...assuming your sending unit is working..gauge is working... oil pump and system is in good repair etc....
a. The high viscosity of the engine oil did not allow oil pressure to build quickly, and may also have caused the system to go into bypass, thus the low oil pressure. Going to Merc Semi Syn and Merc oil filter ought rule this out.
b. Possible engine damage may include; scored engine oil pump - damaged lead/tin overlay of crankshaft bearings (mains and rods) - damage to camshaft bearings - damage to lifters - damaged small end bearings of connecting rods - damage to bearings of engine timing/idler/accessory drive gear train.
Hopefully it's under warranty...
Old 07-16-2008 | 05:38 PM
thanks_don's Avatar
Yes .. I have a 5 year warranty , i'm going look into Semi syn oil too, again thanks
Old 07-16-2008 | 07:01 PM
You may as well stick with conventional oil and save your money. If you don't want a 100% or Full synthetic, then you are wasting your money. Oils are not regulated like they should be, meaning a semi synthetic can basically have 1% synthetic properties to it, and they can call it a semi synthetic, and sell it to you for twice the cost. Additives, as far as I'm concerned, should never be used. If they were supposed to be in there, then they would be. An aftermarket additive can actually have adverse effects on oils, because they are properly made for all different oils, therefore can cause premature breakdown, because the two products in the crankcase can actually work against each other.
07DominatorSS is offline
Velocity Vector
0
04-03-2008 01:45 PM
jeff32
06-28-2006 08:48 AM
FlyFast
13
05-10-2004 11:39 PM
