Redline Oil
Old 07-18-2008 | 04:33 PM
Hydrocruiser's Avatar
Arrow
I am trying Redline and will do an Oil Analysis...I read where it and Vr-1 Valvoline are the one's to use...V-twin as well of course...IF you wanted the premium of premiums.
Also the Mobil-1 Oil that race cars use is called M-1 5W-30r...it is stuffed with ZDDP unlike the regular M-1 10W-30 that only has 800 ppm and would tear the rollers to shreads in an all out NASCAR race.
I have not been able to find a source for M-1 10W-30r...but Amsoil's Signature 5W-30 wt Series 2000 is essentially the same..@ $10/qt.
Hydrocruiser is offline
Old 07-18-2008 | 10:03 PM
C_Spray's Avatar
Diamond Member #001
Originally Posted by Hydrocruiser
SO you are referring to their Racing oil and not the HP oil?
In my days (through 1998), it was all 100% off-the-shelf. If we ever ran low, we'd pick up more on the street. Can't speak for nowadays - rumors of zero weight oils abound....
C_Spray is offline
Old 07-18-2008 | 10:05 PM
C_Spray's Avatar
Diamond Member #001
Also the Mobil-1 Oil that race cars use is called M-1 5W-30r...it is stuffed with ZDDP unlike the regular M-1 10W-30 that only has 800 ppm and would tear the rollers to shreads in an all out NASCAR race...
Mobil One 5w30 is one of the toughest ones out there, according to Bill Maxwell. The only one that VW approved for their turbo deisel SUV. Sounds like a good starting point.
C_Spray is offline
Old 07-19-2008 | 06:56 PM
Arrow
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
Note ZDDP levels on Mobil's chart.
M-1 0W-40 is Porsche.
Many European
vehicles.
HT/TS applications.
Viper approved.
1000ppm of Zinc and Phos
If I were running a European Turbo ie VW/Audi/Porsche'/MB/BMW.....it would have M-1 10W-40 MXT4. 1600ppm of both Zinc and Phos. It is 20W-50 V-twin's brother but in a 40 weight.
http://www.mobiloil.com/USA-English/...4T_10W-40.aspx
Old 12-31-2008 | 02:33 PM
Originally Posted by stevesxm
redline was and remains a very popular racing oil in the forms of racing that i was involved with for 25 years. we tested it every way from sunday both on the dyno back to back against several other types and did longetivity and wear testing in the field. we found it to be an inferior product in all respects. the gearboxes wore out in 1/3 of the time vs normal petroleum based gear oils and the engine wear was also similarly accelerated , in some cases on the small displacement, hi reving motors like the cosworths as much as 50 % ... i.e. to say we would see unacceptable bore wear and ring wear at half the hours/milage as other good oils. their claim to fame was always " more power" but certainly the dyno never said so nor did the performance on the race track.
the single best oil we ever saw in service were the NEO synthetics sold by Baker in california. tolerance to heat was simply unbelieveable and in one case where the driver lost the belt on the dry sump while leading he ran the last two laps w/ zero oil pressure and won with the only damage being that the cam and lifters turned bright blue and there was the most minor bearing scuffing. when we ran the V-6 buicks in the 24 hrs of daytona, i remember taking the motors apart after 24 hours of non stop 8250 rpm racing and finding the bearings still had the pencil marks on them where i had noted the clearences and the rings had zero wear.
problem was the cost was outrageous and the shipping was impossible. the mobile 1 synthetics were cheap by comparison and off the shelf everywhere and were 99% as good. when the redline guys sponsored the drivers with oil and cash, we sold the oil for more cash , used the mobile 1 in the cars and ran the redline stickers as per the contracts.
we never tested or ran the amsoil simply because their hype turned me off so badly that it made me hate them without any good reason... and we were more than happy w/ the mobile 1 products anyway.
its what i run in the boat now...
Interesting.....are any others having success with Redline oils?
MikeStaz is offline
Old 01-01-2009 | 01:56 AM
Red Line's products are unique because they contain polyol ester base stocks, the only lubricants which can withstand the tremendous heat of modern jet engines. These synthetics have a natural multigrade property which allows our chemists to avoid bulking up an oil with unnecessary additive packages. ZDDP is 1,400 ppm and they add moly too. My engines run cooler then other oils I have tried.
I have been using Redline High Performance Oil (Not to be confused with the Racing Oil that is detergent free,...as non-detergent oils are a bit more friction free)...
I have to say I am impressed with their oils and like their 2 stroke oil as well.
The flashpoint of 20W-50 is about the same as M-1's V-twin. V-Twin is about a "55"wt oil and Redline is about a "50 wt" oil based on cst's @ 100*C. Cost is about the same. I hear Autozone sells it as well.
They also make a 15W-50.
Anyone have experience with Redline to share?
Fyi..
I have been getting it in case lots form their online site.
I think the one thing I like about it most is that it stays "cleaner looking" on the dipstick vs. many other synthetics I have used.
http://www.redlineoil.com/products_m...1&categoryID=1
"Cleaner looking" doesn't mean ****. Do an oil anaylsis. Color doesn't mean anything. You can two surgically clean pieces of metal, put a drop of oil between them, rub them together, and the oil will turn black, its a chemical reaction, it doesn't mean the oil is dirty.
07DominatorSS is offline
Old 01-01-2009 | 02:00 AM
Sounds like RedLine is trading wear for less friction in high-stress (pure racing) applications where bearing areas are reduced to absolute minimums. This is a key point in this discussion, as most production-based engines (like boat engines) are designed with a generous margin on bearing area, piston ring widths/tension, etc. Purebred racing engines like Cosworth/Ilmor Indy engines, the racing Buick V6's, Formula One, etc. tend to be built to the very edge, where the oil's film strenghth and lubricity are all-important.
When we started running Mobil One in our CART program in 1990, we traded drums and cases of it to other teams in return for their other sponsors products (beer, mostly). I'm pretty sure that Mobil One was in the crankcase of almost every car in CART, regardless of whether or not it had a "Valvoline", "Shell", or whatever sticker on it. The Mobil guys knew it, and figured that they won almost twice as many races as they could legally claim!
Besides the Unsers, and I'm sure others, they only use AMSOIL. Don't care what their cars say, they use AMSOIL. Al Unser said its the best product he's ever used. Also in NASCAR, Hendrick Motorsports only uses AMSOIL, seems they've been doing pretty well over the last few years!
Old 01-01-2009 | 03:58 AM
all the hendrick cars have M1 in them. i have stood there and seen it with my own eyes.
stevesxm is offline
Old 01-01-2009 | 06:14 AM
I ran Redline Sythetic Gear Oil in my Sanger's Casale V-Drive, didn't run water cooling through the box and never had a heat problem, used to heat up running Fuchs but not Redline, I'm going to run it in my Bravo 1 as well.
What does everyone else recommend to run in the Bravo 1?
Ghostrider is offline
Old 02-19-2009 | 08:46 AM
Amsoil dealers for years have spread a lot of false information around as far as who actually uses their oils. Mobil 1 is used in more professional racing teams than any other oil I can think of.
http://www.bobistheoilguy.com/forums...23#Post1353523
Wow! what a race, one of the best I've seen in a long time, and I could not be more pleased with the results.
I'm on a borrowed computer so will post more when I return home after February 3d, but here is a quick oil report.
Prototype cars:
The first and third place Brumo Porsches use a special synthetic formulation of Kendall GT-1 made for them by Conoco.
The second place Lexus/Riley uses a special Texaco syntheic made by Chevron.
All of the other Prototype cars, Ford, Pontiac, Porsche, and Lexus powered used Mobil 1. And not just some special oil, but the exact same product that Valvoline says is no good. That's right, regular Mobil 1 5W-30. I walked through every pit garage and asked every one of them and a few showed me the cases of oil and I saw one of them pouring it in. They also all use Mobil Delvac 1 75W-90 gear oil.
All of the GT cars except for 4 or 5 also used Mobil 1 5W-30, 10W-30, or 0W-40. The cars that did not use Mobil 1 either used Castrol Syntec or Motul.
In the Koni Challenge Class that raced on Friday, most use Mobil 1 with a few using either Motul or Red Line.
The only car that I saw using any Valvoline product was the Mustang of Jack Rousch Jr.
So, conclusion for me is, Mobil 1 may not work in your grocery getter but it sure darn works in those high dollar race cars.
I will post more when I return home and after my son sends me the disc with the over 400 pictures we took, I will try to post some of them.
If you have never been to this race I highly recommend you go. It's not just a race, it's a happening.
Johnny
The new Dominator oils look like Amsoil's first real attempt at making a racing oil. It's supposedly a PAO & Polyolester based oil. Good stuff. Amsoil doesn't make a bad oil but many of the claims they make are greatly exaggerated.
MikeStaz is offline
