restrictive oil system?
My engines are about 450 hp max, I just wanted to make sure that I am good, i see alot of noats still running this setup but I have had some issues that make me question oiling, I think most of my problem if anything in oiling was using standard pumps with .003 Clearances, I needed HV in my opinion..
I agree thos fittings suck, are there any sweeping 90 I can use that I can still use the stock lines? I am trying to only do what I have to since it is July and I want to get this boat running.
I think the bypass in the oil adaptor is an issue too, I have the 11lb bypass now, I measured and the gen6 30lb valve will fit, I may also just plug it totally. I had crap go through the bearings it looks like and think the bypass had something to do with it.
