engine temp question >
Old 07-19-2008 | 09:54 AM
Default engine temp question
the riser on the starbord engine side feels hot to the touch but the other one feels much cooler,
is this normal,
also just had the boat serviced for overheating problem
and replaced sea pump and recircul pump and thermostate,
when the mech called me he said my temp gauge is also bad(gaffrig) but said acording to his equipment the boat is cooling, but now my gauge light comes on just past 180 degree, he also said sending unit was good
temp gauge is fluctuating, up to 180, then to 200
maybe the gauge is bad? but why is one riser much hotter than the other,
also had some skeg damage fixed, before taking the boat to shop it shifted super smooth, barely hear any engagment, now is seems to shift harder, not ridiculiously
hard but not smooth like before, is there an adjustment for this
454 mag efi with bravo 1
thanks
lennyk is offline
Old 07-19-2008 | 01:20 PM
Codered's Avatar
Dont know the age of boat ect. but i chased a cooling problem for 2 years and found that the hose fitting that comes through the transom assembly had corroded and swelled the hose almost completely shut.I never would have believed it if i wouldnt have seen it for myself. Alot of mechanics and boat people are oblivious to this problem known as Bravo fever,It has been discussed on this forum before , do a search, good luck.
Codered is offline
Old 07-19-2008 | 01:37 PM
offthefront's Avatar
I would not run it any extended period of time until you get it resolved ... Yes the connector does fail (part #20) .... Get a mech temp gauge from autozone (20.00) and check the temp ....the manifolds do clog also ....might not be getting enough flow thru that side ...m
offthefront is offline
Old 07-20-2008 | 08:51 PM
zt260's Avatar
With one riser being much hotter you have an issue. The reasons can be a mile long. Find it before you run it long term or you have much bigger problems. Good Luck!
zt260 is offline
Fast Willy
4
06-12-2008 12:21 PM
ak
1
07-16-2007 06:25 AM
rangerrick63
9
05-07-2007 09:05 PM
aTX427
3
06-03-2005 07:56 AM
timucin
4
06-01-2003 01:29 PM
