496 help needed. >
496 help needed.
496 help needed.
Old 07-19-2008 | 09:30 PM
Registered User
Default 496 help needed.
Anyone have the torque sequence for the 496 MAG HO cylinder heads? Appears that i can not find it anywhere online. Installing the cometeic gaskets but I do not have the torque pattern.
Thanks.
26 Eagle V is offline
Old 07-20-2008 | 10:25 AM
For the truck engine start in the center 2 then go clockwise moving outward till they are all tight.
diggster69 is offline
Old 07-20-2008 | 04:14 PM
all that is 454 chevy big block that bin stroke ckeck with a speed shop in your town they will more then willing to help. remember its a chevy that flots on weter
northfl is offline
Old 07-21-2008 | 08:07 AM
kubcat's Avatar
Thanks.
Straight from Volvo service manual. Not very clear, not sure if it is the beers I drank or the phone camera...
kubcat is offline
Old 07-22-2008 | 09:58 AM
Registered User
THanks for the Pic. Get the gaskets in & torqued. Now lets see if the darn thing actually runs. Had some issues when removing the original Intake manifold to install a Whipple. An intake manifold bolt broke off in the cylinder head just below the boss. Then, while drilling the center of the bolt & trying an easy out. The easy out tip broke off. Well after conteplating the mess I figured now would be a good time to remove the cylinder heads & have a machine shop remove the broken bolt & easy out while installing the cometic gaskets to go with the WHipple. Hopefully it'll still run after all the work!
Old 07-23-2008 | 07:55 AM
kubcat's Avatar
The workshop manual also has a specific procedure for the intake manifold. It emphasis the importance of getting it right to prevent leaks.
If you want I will post the torquing procedure.
kubcat is offline
tfarmer
Sonic
4
07-09-2008 03:08 PM
long duck dong
05-24-2008 04:50 PM
alecsammy
1
11-05-2006 07:37 AM
alecsammy
4
05-12-2006 09:22 PM
Jeff Pierpont
0
01-27-2005 10:53 AM
