500efi-575sci >
500efi-575sci
500efi-575sci
Old 07-30-2008 | 08:57 PM
INDY27's Avatar
Default 500efi-575sci
Does anyone have oem specs on both? Mercury Racing no longer has them on their website. Do they have the same rods, block and heads but different pistons, cam, lifters and accesories?
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 07-31-2008 | 10:30 AM
500 EFI's have 8.75:1 compression and hyd roller cams,
575's have 7.5:1 compression and flat tappet hyd cams.
575's have manley H-beam rods, as I recall, the first
500EFI's had GM rods, the later used Manleys
Both have GM rec port heads.
The 500 EFI is MPI...The 575 is TBI
Hope that helps
JaayTeee is offline
Old 07-31-2008 | 11:14 AM
INDY27's Avatar
Thanks, that helps a little. A freind of mine here has a shop and his personal boat is a 2003 w/ 500efi's, he had to go into one and said it had the h-beams with mercury racing in the side. He said he has also pulled apart 575sci's from a customers 42 Lighning and they had standard rod like a 502efi/mpi. Just trying to set the record straight. I am looking at buying a 2003 36 Spectre w/ 575sci's and wanted to know for sure.
INDY27 is offline
Old 07-31-2008 | 12:16 PM
Check these conn. rod part #'s out
this is from the first s/n batch of 500EFI's
http://www.mercruiserparts.com/Show_...iston+Assembly
( part # 614-9641t)
this is the next batch.....the rest of the production shows this
# also
http://www.mercruiserparts.com/Show_...ler+Components
( part # 614-8m8020323)
This is a 575
It uses the same part # rod throughout the production run,
and is the same part # as what the 500EFI's used after
the first batch
The 614-9641t is the same part # used in HP500's
which used GM rods
Go for it......575's are a great engine....you
wont be dissapointed.
JaayTeee is offline
Old 07-31-2008 | 12:25 PM
INDY27's Avatar
Thanks JaayTeee! Never crossed my mind to check Bam's site.
INDY27 is offline
Fever575
Do It Yourself, Boating on a Budget
4
07-31-2008 11:59 AM
performancemary
Powerquest
13
05-26-2005 12:30 PM
performancemary
05-13-2005 02:31 PM
aTX427
14
05-21-2004 07:43 AM
BAJA WILL
5
01-17-2003 09:36 AM
