How do you backflush(clean out) on 496 engines >
Old 08-02-2008 | 03:26 PM
bowtye8's Avatar
Default How do you backflush(clean out) on 496 engines
What hoses do you backflush through. When I follow from the seapump.....It appears to goto the power steering cooler then around to the oil cooler then to ???(heat exchanger)
Its a tight fit. My rib are sore, Arms bruised. had to take a break.
Had high H2O pressure. Sending unit is on the pwr steering cooler so I would assume it after that. Oil cooler.
I just changed the impellors last week.s Both (engines) were good. They were originals 140 hrs No blades missing. Maybe just some gunk up in the coolers or ???????
bowtye8 is offline
Old 08-03-2008 | 08:34 AM
satisfactionII's Avatar
I don't have the answer but would like to know how it's done as well.
satisfactionII is offline
Old 08-03-2008 | 08:44 AM
I take of the outlet side of the sea pump and the inlet side of the heat exchanger and flush toward the pump. Then take off both end caps on the heat exchanger and flush starboard to port. The rubber gaskets on the heat exchanger are reuseable just be carefull with them.
Plane Silly is offline
Old 08-06-2008 | 10:51 PM
Reckless32's Avatar
Rough Seas Lie Ahead
Using the intake line from to the exchanger, wrap a garden hose with some tape to help make a good fit inside the feed hose. Use a clamp to tighten it up. Then with your pump off and lhose open on the other end hold your hand over the hose to build up back pressure then release. Do this several times and it will help blast out any stuck debri.
Reckless32 is offline
Old 08-08-2008 | 07:50 PM
bowtye8's Avatar
All above are great point todo. I would add remove teh incoming hose to the oil cooler. The cooler is under the port manifold. Actually not that bad of a hose to get off. I then stuck my finger in the incoming side of the cooler. Yikes it was filled with gunk. seaweed etc... I then remove the hose from the main exchanger and back flushed the water into the cooler so water comes out the incoming end. I kept poking my fingers in there(oil cooler) to loosen things up.
bowtye8 is offline
26sonic
05-05-2009 03:42 PM
496mag
11
03-07-2008 08:31 PM
26sonic
06-10-2006 01:57 PM
26sonic
03-01-2006 08:49 AM
Harper220
06-27-2005 06:34 PM
