502 headgasket >
502 headgasket
502 headgasket
Old 08-04-2008 | 06:53 PM
Secretformula's Avatar
Default 502 headgasket
I am replacing the headgaskets on a 502 efi mag what sealer should I use on the headgasket to ensure a good seal?
Secretformula is offline
Old 08-04-2008 | 07:38 PM
None !
Modern head gaskets have thier own coatings that seal them while allowing them to move as the heads and block expand and contract.
Bill Koustenis
Advanced Automotive Machine
Waldorf md
BillK is offline
Old 08-04-2008 | 08:06 PM
Registered User
Yes. And only use a marine head gasket. Fel Pro makes an excellent one. make sure you follow the retorquing instructions or you'll be disassembling your new engine again- very shortly.
Chris Sunkin is offline
Old 08-04-2008 | 09:41 PM
Vinny P's Avatar
I hate the winter!!
Personally, I Like Cometic headgaskets. A bit more $$, but worth it. No need to retorque them.
Vinny P is offline
Old 08-04-2008 | 09:49 PM
I've got a mild build 502 mag efi that has leaking head gaskets. Only 80 hrs. Built by Baker Eng. I know the heads were never retorqued. Is that why their leaking, who knows. Put me out of a boat for the summer though.
cloudmaster_321 is offline
Old 08-04-2008 | 11:03 PM
No sealant as Bill K said.
Could be. Fel-pro's don't need retorqued after a heat cycle. They get retorqued upon the initial install. Torque all head bolts in proper order and then loosen each bolt one at a time and re-torque it.
Griff is offline
Old 08-05-2008 | 07:32 AM
Registered User
They put a little paper slip in every package that details the procedure. I'll see if I can dig thru the trash and I'll post it.
This is the marine gasket- I have no idea about their automotive gaskets.
Old 08-05-2008 | 08:20 AM
Felpro MLS gaskets are like flypaper. They'll stick to the wall!
kennyo is offline
Old 08-05-2008 | 12:32 PM
What I posted is what came on the directions in my felpro marine gaskets related to the need to retorque.
Griff is offline
Old 08-05-2008 | 01:52 PM
Registered User
I'm going to have to dig that slip out. Maybe a recent change?
