2000, 502 mag? >
2000, 502 mag?
2000, 502 mag?
Old 08-05-2008 | 04:25 PM
noyzee's Avatar
Question 2000, 502 mag?
how good are these motors? the 415 mpi motors?
i here mixed things about the 502, but most people down he carb 502 not the mpi.
anything to look out for?
noyzee is offline
Old 08-05-2008 | 04:26 PM
noyzee's Avatar
ps, how fast would the stock motor push a 27 fever?
noyzee is offline
Old 08-05-2008 | 04:36 PM
satisfactionII's Avatar
solid as a piece of granite. They do vapor lock if it has the VST. have seen them go 800-900 hours without a rebuild. If you run it out quite a bit then refresh the heads every 300 hours.
satisfactionII is offline
Old 08-05-2008 | 04:39 PM
noyzee's Avatar
ok,cool. im not sure but like i said i have heard people say the 502 is iffy, but i dont know why.
seems like they are good tho
noyzee is offline
Old 08-05-2008 | 05:42 PM
as he said solid as a rock if they have the vst they do vapor lock after or during a long idle, but there is ways around that
rssteiny is offline
Old 08-05-2008 | 07:08 PM
bcfountain's Avatar
Registered User
Default 502mpi mag
i have a 27fever w/502mpi.best thing about it is,get in it start it up,it idles,good dock maners,and gets great gas millage,2.5to3miles per gallon at 45mph.not the fastest boat,but super reliable.
bcfountain is offline
Old 08-05-2008 | 09:13 PM
obnoxus's Avatar
Charter Member #1171
The 2000 is not a VST motor its cool fuel,,, much better,,,,, darn thing will run 1000 + hours taken care of.
I would guess upper 60's low 70's in a 27'
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 08-05-2008 | 10:59 PM
noyzee's Avatar
thanks for the info guys. im going to go look at the boat this weekend see how it is. we'll see
noyzee is offline
Old 08-05-2008 | 11:19 PM
They tend to use a little oil, but I reduced the oil consumption on mine by switching to mobil 1 15-50.
2000 engines have cool fuel and don't have the vapor locking problem. Mine have 320 hrs and run perfect.
Griff is offline
Old 08-06-2008 | 08:01 PM
I have 1997 502 mags with about 370 hours and still run great.
Other than maintenance the only thing I had to do is replace both engine
water recirculating pumps because they were leaking.
johnny b good is offline
