Its Bravo Xr >
Its Bravo Xr
Its Bravo Xr
Old 08-17-2008 | 04:44 AM
Originally Posted by Mr Gadgets
Steve,
How much variance in lash are you seeing on the upper XR gears?
I can keep the 'averages' ( x3 or 2 x3 ) and stay within spec, but the highest and lowest are out of the spec.
Without checking records .005" to .006" spread.
The spiral gears ( X ) are very accurate, .001 to .002 spread.
Steve
SpeedMaster is offline
Old 08-17-2008 | 08:14 AM
KAAMA's Avatar
Originally Posted by SpeedMaster
ALL the XR's I have done have had a variance of backlash on the drive shaft housing pinion.
My own boat and my customers are getting better durability now with X drive shaft housing gears. Steve
So then, what are you saying Steve? You are finding the X slant cut gear is now better/stronger than the XR straight cut gear? Or are you only saying that the X gear is a more reliable/stronger piece than what it once originally was??? Should I switch over to the X slant cut gears next time I rebuild or what???
I have XR gears/drives at this time....so far 200hrs on the top gears, 565cid naturally aspirated with about 670lb of torque in 32' Active Thunder turning 5400-5600rpm on top, Amsoil synthetic gear lube.
I am very curious as to what you implying here if anything---looking for clarification. Thanks
KAAMA is offline
Old 08-17-2008 | 09:18 AM
RICHARD CUNY's Avatar
Default Xrits
Steve and all in decussion
I am running a older 87 baja 240that i converted to teague 620 ITS Bravo XR boat runs near 80 but i have to shorten up the drive because it is in a alpha hole and is runnung very deep causing the boat to run very high.This is my first season back to boating after coleges and weddings and all that stuff. this decussion sure makes me wonder what I am in for should i consider contacting someone in the gear trade to have new gears heat treated or just go with another stock set.
Rich
RICHARD CUNY is offline
Old 08-17-2008 | 10:27 AM
Default Reply
steve sorry I have a 5600 chip changed it from 6000 floated a valve ans shortened a manley push rod my marina said they thought 6 was just a bit high for roller hydralic.
Rich
Old 08-17-2008 | 06:11 PM
I am not implying anything.
Our application is water ski racing, 20' boats towing skiers,
my own engines have been a 480ci 740hp 640tq and a 565ci not dyno'd, but you get the picture.
XR gears on customers and my boats about 4 hours before pitting the pinion, X gears- haven't failed or worn any yet- 6 hours on my boat and customers with about 80+ hours.
I believe, the XR's are stronger gears, BUT when you look at there rotating action they 'step' from tooth to tooth, whereas the X's have multiple teeth in contact and have a 'rolling' action.
With your boats, heavier weight and lower rpm for peak torque you probably need the XR's for the strength, but who knows what would happen, ie I am not advocating changing.
At 200 hrs, I would think that is good life. I have commercial fisherman who wear the brass shift rings in 400 odd hours.
The XR gears are Near net forged and NOT machined on the tooth surfaces, the X and standard gears ARE machined on the tooth surfaces, therefore the more consistent backlash.
I have had the gears (both styles) metallurgically tested and composition is almost identical and the base metal is good quality, they recommended the next grade 'higher'. This was done at BHP Billotin (sp?).
I have also run XR gears with Smity's treatment, they looked good, the backlash loop was closer, but ultimately did not last longer in OUR APPLICATION.
nb. This is in no way a dig or slight on what Smitty does.
Steve
Old 08-17-2008 | 06:44 PM
Rich
What oil, brand and grade?
The only 'failures' ( not wear) I have seen with my setups is 1 boat ran 75/90 oil xxx brand, changed to 80/140 xyx oil and no more problems.
Steve
Old 08-18-2008 | 01:04 AM
The NXT uses the gears for reverse, other wise it is straight through in FWD. Think of an XR on it's side with the input shaft entering the top of the drive and output the bottom of the drive. When in FWD the input shaft is connect directly to the output shaft by the cone locking into the bottom gear. When in Rev the pinion gear is used to transfer motion from the top gear to the bottom gear, used as an idler gear, causing the output shaft to rotate in the opposite direction. I hope that makes sense??
LH and RH rotation is handled in the drive, by placing the driven gear in the top or bottom position.
If they had any weak points, I think we would have heard about it by now. Doesnt seem to be much negative press on the NXT to date..
I lost it there somewhere, but what your saing? NXT do not use a tranny or yes ?
But only for reverse its a bravo gear ?!
MMMHHH , ok ............i quess i still lost you ???????
DareDevil is offline
Old 08-18-2008 | 07:54 AM
KAAMA's Avatar
KAAMA is offline
KAAMA's Avatar
[QUOTE=SpeedMaster;2655711] I believe, the XR's are stronger gears, BUT when you look at there rotating action they 'step' from tooth to tooth, whereas the X's have multiple teeth in contact and have a 'rolling' action. [QUOTE]
Yes, that is the way it has been described to me by the person who builds my drives (Mr. Gadgets)
[QUOTE=SpeedMaster;2655711] With your boats, heavier weight and lower rpm for peak torque you probably need the XR's for the strength, but who knows what would happen, ie I am not advocating changing. At 200 hrs, I would think that is good life. I have commercial fisherman who wear the brass shift rings in 400 odd hours.[QUOTE]
This may be a stretch in thinking, but with my boat having TWO drives, it might be safe to say that with it being only a 32footer it is probably close to the same weight/outdrive/HP/Torque ratio/range as your ski or test boats give or take---of course different applications. Perhaps the X gear may be a better gear (???)---that's the BIG question of the day.
Your entire response was very intriguing. Thanks
KAAMA is offline
Old 08-18-2008 | 04:28 PM
Default Gear Lube
STEVE
The last oil change was this season i used Mercury High Proformance Gear Lube + does not say what viscocity it is just Part # 92-858064k01 could this be my problem.
Rich
