Found this in my oil filter?? >
Old 08-10-2008 | 05:32 PM
Hope it's not bearing material....
Carder is offline
Old 08-10-2008 | 05:47 PM
Registered User
Only steel is magnetic, which he said it is. Looks to be iridited- a surface treatment for hardened steels. I've seen steel "flake" under heavy loads- it looks like scale flaking off. I have also seen these types of failures on case-hardened steel- the treatment only penetrates a few thousandths.
My guess- you've lost this piece from your oil pump.
Chris Sunkin is offline
Old 08-10-2008 | 07:22 PM
Vinny P's Avatar
I hate the winter!!
Thanks for all the ideas. It seems I have a very unusual situation brewing here. Today, I removed the check valve after the pre-luber. It was stuck open. It had a small piece of brass looking material in it, that was holding the valve open a bit. It was not magnetic. No way did these 2 pieces originate from the same place.
The next thing I took apart was the pre-luber pump. I found a small piece of the corner of 1 of the impellers that was broken off. I dont have a picture, didnt take the camera to the boat yard. That explains the lower oil pressure. As I suspected, the slightly hung open check valve must have been alllowing oil back through the pre-luber and into the oil pan. I ran the boat today, oil pressure was back to normal. No noises, engine ran perfect. Everything is good, EXCEPT where the hell did the piece of metal in the oil filter come from? I am not running a bronze distributor gear. I believe this piece is too big to pass through the oil passages in the block. I swear, the filter was built around this thing. The only thing I can think of, is to run it for a few more hours and cut the filter open again. Here are a few more pictures.
Attached Thumbnails Found this in my oil filter??-filter-2.jpg   Found this in my oil filter??-filter-3.jpg   Found this in my oil filter??-filter-4.jpg
Vinny P is offline
Old 08-10-2008 | 07:35 PM
Elite Marine's Avatar
Originally Posted by boatme
How did a pencil get in your filter??
Sorry Vinny, but that funny.
Elite Marine is offline
Old 08-10-2008 | 07:41 PM
Originally Posted by ThruHull
Looks like a tooth from a bronze distributer gear to me, but that would not explain your oil pressure drop
exactly what I was thinking
otis311 is offline
Old 08-10-2008 | 07:47 PM
Vinny P's Avatar
I hate the winter!!
more, remember this piece is magnetic
Attached Thumbnails Found this in my oil filter??-filter-5.jpg   Found this in my oil filter??-filter-6.jpg
Vinny P is offline
Old 08-10-2008 | 07:48 PM
Vinny P's Avatar
I hate the winter!!
Yeah, I was waiting for that. Surprised it took as long as it did.
Vinny P is offline
Old 08-10-2008 | 07:58 PM
Panther's Avatar
Frank's Marine Service
Good thing the filter did its job!
Have you noticed any difference in oil temperature?
Panther is offline
Old 08-10-2008 | 08:04 PM
Vinny P's Avatar
I hate the winter!!
No, everything was great today.
Vinny P is offline
Old 08-10-2008 | 08:39 PM
Vinny, could it be a peice of the main thrust bearing ? don't know how it would get there though ???? good luck, Rob
ezstriper is offline
