Found this in my oil filter?? >
Old 08-10-2008 | 09:18 PM
Vinny P's Avatar
I hate the winter!!
Originally Posted by ezstriper
Vinny, could it be a peice of the main thrust bearing ? don't know how it would get there though ???? good luck, Rob
No, it is magnetic. I am at a loss on this one.
Vinny P is offline
Old 08-10-2008 | 09:33 PM
Did you check the oilpan for any stuff ?
befor you run that engine i would check it.
and pull the valvecovers and check the rockers and springs.
DareDevil is offline
Old 08-10-2008 | 10:19 PM
Mr Gadgets's Avatar
Charter Member #601
It could be a piece of junk out of my motor, Vinny!! Not sure how it would have gotten all the way to your oil filter??? That is a good puzzle!.
But you got me to thinking about my oil psi.. from last year. Time to tear down the oil system and check the check valve..
Mr Gadgets is offline
Old 08-10-2008 | 11:09 PM
JCPERF's Avatar
Originally Posted by Vinny P
more, remember this piece is magnetic
Could be a piece of the oil pump pickup.I have seen on certain pickups when pressed in the pump they peel the coating and goes through the gears.
JCPERF is offline
Old 08-11-2008 | 04:54 AM
tomas_wallin's Avatar
What about a piece from a hardened drill or other tool from when machining the engine block?! It could have been stuck in some oil passage from when the block was new and just got loose and picked up by the filter...
tomas_wallin is offline
Old 08-11-2008 | 01:26 PM
Almost looks like a small piece of a single edge razor. The back side with the rolled over safety edge.
Fast Algae is offline
Old 08-11-2008 | 01:34 PM
txriverrat2001's Avatar
That's what I was thinking ...
Or as he said - it looks lilke the filter was built around it ... hell, maybe it was in the filter to begin with.
txriverrat2001 is offline
Old 08-11-2008 | 05:46 PM
Vinny P's Avatar
I hate the winter!!
I dont think so, it is too flat. If this went through the pump gears, I would think it would be more mangled up.
I spent alot of time thinking about this one. I think I finally came up wth something logical. What about a piece of the oil thermistat? I actually have a spare one here. It may not be identical to the one in the filter head. I dont know if anyone here has ever looked at one closely, but there are alot of small parts to one of those things. I checked it out with a magnet, most of it is not magnetic, but some of it is.
I feel confident that is the origin of this piece.
Vinny P is offline
Old 08-11-2008 | 06:30 PM
Registered User
You really only have two choices...
1. take the motor apart piece by piece until you find where it came from and what damage it's done.
or
2. Take a chance on reducing your expensive motor to worthless scrap.
Chris Sunkin is offline
Old 08-11-2008 | 07:09 PM
Wobble's Avatar
SORE MEMBER
is your filter after the oil cooler? was the oil cooler used with another motor? if so you may be seeing some trash from a previous motor failure
Wobble is offline
