Found this in my oil filter?? >
Old 08-11-2008 | 07:18 PM
  #31
Hydrocruiser's Avatar
Maybe something from your oil pump?
Check the next filter too...
Hydrocruiser is offline
Old 08-11-2008 | 07:26 PM
  #32
Vinny P's Avatar
I hate the winter!!
Originally Posted by Wobble
is your filter after the oil cooler? was the oil cooler used with another motor? if so you may be seeing some trash from a previous motor failure
The filter is part of a thermistatically controlled filter head. When the oil is cold, and the t-stat is closed, oil flows around the closed t-stat, through the filter and back to the engine. When the oil is hot and the t-stat is open, oil flows through the t-stat, the cooler, then the filter and back to the engine.
This cooler has never hooked up to any engine failure.
Vinny P is offline
Old 08-11-2008 | 07:27 PM
  #33
Vinny P's Avatar
I hate the winter!!
If I see no other issues, I plan on running it a bit more, then pulling this filter for inspection.
Vinny P is offline
Old 08-11-2008 | 07:45 PM
  #34
Could it be part of the filter casing? Or a part of the filter?
Just a guess?
orthos1 is offline
Old 08-11-2008 | 08:14 PM
  #35
wow, this a puzzle, keep us posted. As much as I would like to think it was filter from manufacturing it etc. that is two pieces of FOD right. (sliver holding open the bypass and this. Too much foreign material, I vote tear it apart. Too much stress and money not too.
happy hours is offline
Old 08-11-2008 | 08:50 PM
  #36
Vinny P's Avatar
I hate the winter!!
Well, I found where the small piece of debris that was holdong the check valve open came from. It was a small corner of the pre-luber pump impeller. The mystery is the larger piece.
Vinny P is offline
Velocity Vector
0
04-03-2008 01:45 PM
Blue by You
42
09-18-2006 04:28 PM
powerguy
5
08-04-2002 07:44 PM
